09-24-2014, 02:47 PM #1
Oil Pressure, unstable after A/C Compressor install.
So today I reconnected my A/C Compressor and recharged my A/C system. However while driving it I noticed the oil pressure has dropped a bit and move up and down a little at idle. I'm not sure if the getting the A/C compressor reconnected caused this if it it's something else. My car is a 1999 Z28 with a T56 and 202k miles. Any help would be appreciated.
09-24-2014, 04:27 PM #2Spaz is My Mentor
more importantly is what are the oil pressure numbers reading at?
09-24-2014, 04:35 PM #3
It's in between a quarter and half at idle.
09-24-2014, 04:39 PM #4Spaz is My Mentor
20 -40 psi?
Should be around 30-40 psi at idle for stock car. (depending on oil weight and engine wear condition)
200k miles
on making that milestone. I killed mine around 165k.
A little bit of drag on the motor might increase/decrease the oil pressure because it's attached via belt to the crank but shouldn't be enough to really notice.
Keep an eye on the OP gauge.
09-24-2014, 08:27 PM #5
Well I'd say it's about it moves around from 25 to 35. Never goes to 20. Before it would idle at 35psi but it just seems like it's moving a bit too much. It doesn't do it all the time but it just kind of keeps me on edge when I'm at a stop light and I'm watching it move back and forth and back forth. I'm no expert but I don't think it should move around so much at idle but then again this is the first time I've ever had the A/C compressor, it was never connected when I purchased the car.
09-27-2014, 03:45 PM #6
If your AC compressor is engaging and disengaging at idle that can affect the engines rpm. In turn, this could conceivably result in what you are seeing as the compressor cycles on and off. Shut the AC off and see what it does.
Question: AC compressor, dryer, and orifice tube install
By El Toro Loco in forum External EngineReplies: 1Last Post: 04-22-2010, 06:00 PM -
Compressor Install Question
By pajeff02 in forum ToolsReplies: 14Last Post: 12-24-2009, 06:53 PM -
No pedal pressure after clutch install
By chevyss1234 in forum Manual TransmissionReplies: 7Last Post: 12-23-2009, 06:23 PM -
clutch has no pressure after t56 install
By shanepatrick1230 in forum Manual TransmissionReplies: 3Last Post: 05-06-2008, 05:32 AM -
LS1 A/C compressor install writeup??
By 6spd in forum General HelpReplies: 1Last Post: 08-17-2006, 03:54 AM
