11-30-2006, 06:38 PM #1Junior Member
- Sep 2006
- Smithtown NY
White- 1999 T/A
Time for a new tranny..... best option?????
my trannys shot n wont shift past second, my mechanic said he ran a pressure test and the numbers were all over the place. so its time for a new tranny. what would be the best option. get a brand new one, totally overhaul my tranny, or get a tranny to swap out???? if i rebuild i figured it get it done with all HD parts, shift kit an all.. what do u guys think would be the best way to go to bulletproof this thing so this is the LAST time i touch the tranny
12-01-2006, 03:45 AM #2
It depends on what your goals are in the long run. Since you are gonna have too replace, Do you plan on putting in some more power? Keeping it stock? If your gonna keep it stock then a cheap way out is too just pick up a used tranny. If you plan on adding more power than i would build the tranny for that power band. Complete overhaul and rebuild with stronger parts and shift kit if you choose.
12-01-2006, 07:58 AM #3
rock has went out of business
edited by moderatorLast edited by mrr23; 12-03-2006 at 09:27 AM.
12-02-2006, 07:24 PM #4Car and Truck Trans Tech
- Sep 2006
- Wood Dale Ill.
12-04-2006, 06:42 AM #5Junior Member
- Sep 2006
- Smithtown NY
White- 1999 T/A
its all good.... trannys at a local shop whos been a family friend for over 10 years. drove by yesterday and my car was up on the lift, flywheel exposed n i could see my tranny layin on a table in the back. it lookd like they just started to dismantle it. should be gettin a call today bout how it looks and wut were gonna put back in it.
C2 Transmission Install - LS1 Tranny Time
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 09-15-2009, 11:00 AM -
tranny time
By mark21742 in forum GTOReplies: 14Last Post: 08-12-2009, 11:35 AM -
YAY!! New tranny time!!!
By JoshieDoom in forum Almost Anything GoesReplies: 8Last Post: 07-25-2008, 07:50 AM -
Does anyone have an Auto Tranny 4L60E tranny layin around thats in good shape?
By LT1RacerMan23 in forum Parts Wanted / TradeReplies: 5Last Post: 01-28-2008, 01:48 PM -
Time to change engine and tranny mounts?
By SR71 in forum General HelpReplies: 3Last Post: 02-23-2006, 11:33 PM
