02-23-2006, 05:12 AM #1
Time to change engine and tranny mounts?
Hi guys,
Some mornings, when I put my car into reverse I feel some heavy vibrations. I get a little while the car is in drive, but not really as noticable as when it's in reverse. And not everyday, but every now and then it sounds like something is "knocking" underneath the car when I'm sitting in one place with the engine running. Now initially I thought it was the transmission possibly crapping out on me, but it shifts gears fine. So now I'm starting to think that it's either the trans, or motor mounts. Can someone please help me. It's really starting to drive me crazy.
Thanks,
Terry
Black 98' Trans Am; SLP Lid, FRA, Flowmasters, Hotchkis STB, Hotchkis SFC
02-23-2006, 08:36 AM #2
Mine has a few of those "Odd" noises from time to time also. One thing you may want to check is if when you are moving does the bump tend to stop or get less.? What was happening with mine is I put some long tube headers in that ran close to one of my sub frame connectors. Some days would be worse than others but it was bad when sitting at a light. Like I said, it turned out to be the headers banging on the SFC when at idle and in gear. It did not happen as much while out of gear or sometimes at all. Anyhow, I would just check around under there for things that are close together and you may find your issue. The trans mount I doubt would stop this noise and if the motor mounts are flexing that much at idle you need to replace them anyway! Good luck!
02-23-2006, 03:38 PM #3
Could be alot of things.. Most likly its the tranny mount. They tend to dry rot and crack.. Could also bee your cross member if the bolts have gotten loose.
02-23-2006, 11:33 PM #4
Thanks guys, I'll get under there this weekend, probably Sunday. Can't do it tomorrrow...the little woman's forcing me to put on a penguin suit to come with her to some fundraiser thingy filled with people from her sorority and politicians. Damnit. Anyways, I'll check the cross member and try and check the motor mounts. Thanks again.
Auto tranny Mounts?
By 89RS&98Z28 in forum DrivetrainReplies: 8Last Post: 05-11-2012, 08:16 AM -
Question: Urethane tranny and torque arm mounts. Vibration?
By yellowv in forum DrivetrainReplies: 16Last Post: 08-23-2009, 02:10 PM -
NIB: 98-02 LS1 Poly Motor/Tranny Mounts $50
By CWW17 in forum Parts For Sale / TradeReplies: 5Last Post: 11-20-2007, 12:36 PM -
Changing Motor and Tranny Mounts
By kool-aide in forum General HelpReplies: 12Last Post: 07-13-2007, 01:23 PM -
Clunk Sound Tranny Mounts/
By chvydav99 in forum Automatic TransmissionReplies: 0Last Post: 08-28-2006, 01:59 AM
