Results 1 to 17 of 17
    S. Florida
    98 Formula /93 Z28
    Urethane tranny and torque arm mounts. Vibration?
    Hey guys just got done with my clutch install. I did a Monster Level 3 w/ chromoly flywheel and I replaced the tranny and torque arm mounts with Urethane as both stock mounts were shot. I now have a pretty pronouced vibration. Is this normal with the urethane parts or do I have another issue? The clutch seems to be working awesome.
    Nov 2008
    harrisburg pa.
    02 vette vert
    Quote Originally Posted by yellowv View Post
    from what ive seen thats normal. but, you need to do the motor mounts too. soft motor mounts+stiff trans. mount=something broke.
    Wisconsin
    2001 Camaro SS M6
    Where did you buy the mounts at, also would like to know where to get urethane motor mounts too if anyone knows.
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    S. Florida
    98 Formula /93 Z28
    byunspeed
    S. Florida
    98 Formula /93 Z28
    Quote Originally Posted by dklowrider View Post
    Thanks.
    Wisconsin
    2001 Camaro SS M6
    byunspeed
    Thank you very much sir
    Wisconsin
    2001 Camaro SS M6
    That site rocks..... would have saved almost $100 dollars on my exhaust
    Nov 2008
    harrisburg pa.
    02 vette vert
    i didnt mean this to sound like you broke something, i meant you will or could likely break something.
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    I have stock motor mounts/poly tranny and tq arm mount and I had vibes probably 1 day. After that it went away and my car continues to feel solid. I put all that on last year and nothing's broken. I suggest the op allowing the parts to break in.
    S. Florida
    98 Formula /93 Z28
    Quote Originally Posted by 7camaro7 View Post
    Yeah I figured the stiffness would lessen with time.
    Nashville, TN
    02SS6spd VERT!
    just take it easy on your car for about 1 tank of gas.
    S. Florida
    98 Formula /93 Z28
    I'll go two tanks. Got to break the clutch in.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Did you get a E.S. or Prothane poly trans mount?
    S. Florida
    98 Formula /93 Z28
    Prothane for the tranny and ES for the torque arm
    Ca.
    Navy Blue
    1999 Camaro Z28
    If you had the E.S.trans mount you could cut or grind down the 2 pre-load bumps and eliminate most of the vibration. I've ran mine that way for a good 7 yrs. There's still a little more vibration then stock , but it's very mild.
    Nashville, TN
    02SS6spd VERT!
    mine feels like stock too, but tighter. no extra vibes at all.
    Wisconsin
    2001 Camaro SS M6
    I believe I will get the motor and tranny mounts at once since its only $75 dollars. I called a stealership and for the tranny mount alone (ACDelco/stock replacement) was $110 dollars Wait til I get my K-Member
  1. Auto tranny Mounts?
    By 89RS&98Z28 in forum Drivetrain
    Last Post: 05-11-2012, 08:16 AM
  2. Help: Tranny Rattle/ Vibration
    By Cobra Killer in forum Manual Transmission
    Last Post: 04-19-2010, 03:31 PM
  3. Vibration with poly motor mounts and cam?
    By Huskerz1 in forum External Engine
    Last Post: 06-12-2007, 10:59 AM
  4. HELP polly tranny mount vibration
    By vecaj in forum Drivetrain
    Last Post: 11-07-2006, 08:39 PM
  5. Clunk Sound Tranny Mounts/
    By chvydav99 in forum Automatic Transmission
    Last Post: 08-28-2006, 01:59 AM
