11-28-2006, 05:42 PM #1Junior Member
- Dec 2005
- québec
red- 98 Z28 camaro M6 hardtop
unscrew driver side upper mount shock bolts(98' Z28)
anyone has tricks to unscrew the torx head bolt from the upper shock assemblie under the brake master cylinder(driver side) without pulling out the master cylinder on a 98 Z28???
tanks! -paq-
11-28-2006, 05:51 PM #2
all you have to do is take the two nuts off for the master Cly. leave the line on, pull the master Cly off the studs and push it out of the way the lines will bend. but don't be rammy or you might fuck up the lines
11-28-2006, 06:15 PM #3
yep you have to move the master cylinder out of the way. do what s99ta described and you are good to go.
11-29-2006, 04:24 AM #4Junior Member
- Dec 2005
- québec
and the master cylinder will not loose any fluid or do i will necessary obligated to change seal or gasket when i will do this???
tanks!
-paq-
11-29-2006, 06:20 AM #5
no you just have to lossen the bolts to move it enough to get at the torx bolts.
I actually replaced the torx with grade 8 bolts so the next time I will not need to mess with the master cylinder the next time I switch out the springs.
11-29-2006, 08:01 AM #6Junior Member
- Dec 2005
- québec
front shock lower springs, shock mount mod?
By JayTA98 in forum Suspension and HandlingReplies: 0Last Post: 12-24-2011, 03:48 AM -
rear upper shock mount access
By sunsetLS1Z28 in forum Suspension and HandlingReplies: 8Last Post: 12-31-2010, 06:27 AM -
Upper rubber shock mount problems
By Banshee1967 in forum General HelpReplies: 1Last Post: 11-05-2006, 06:20 AM -
WTB driver side door switches mount clips
By iceman504 in forum Parts Wanted / TradeReplies: 0Last Post: 10-10-2006, 04:54 AM -
torque spec for shock mounting bolts front/rear
By trainingdragon in forum Suspension and HandlingReplies: 5Last Post: 06-16-2006, 07:25 PM
