    Dec 2010
    Poplar Grove Illinois
    Sunset orange
    Camaro Z28 2002 LS1
    rear upper shock mount access
    2002 Z hatchback
    R&Ring rear shocks.
    The bottom is easy enough -DUH
    But the upper mount access....................
    I heard someone say cut the carpet.
    I just can't cut on Suzzy.
    (I don't want to cut the carpet).
    how do you remove the rear seat speaker trim panels so the carpet can come up easilly?
    I don't want to bust up any plastic.
    Hints - photos
    please help.
    phoenix
    04 2500 4x4 crew cab
    just remove the rear trunk panels and peel the carpet forward.
    I don't have any pictures, but there is no need to cut carpet or tear anything up. Just take your time and remove the plastic pieces and pull the carpet back. There will be a foam pad in each hole where the shock bolt comes through. Once you get there, you will realize how easy it is.
    Dec 2010
    Sunset orange
    Camaro Z28 2002 LS1
    Quote Originally Posted by az gt eater View Post
    Thanks for the encouragement.
    I just carefully folded it around a little then peeled it back like you said.
    Got the shocks R&Red.
    Edelbrock 34031s
    Install was easy.
    But I still have my clunk sound over bumps from right rear.
    Bearing? If I grab the rear right tire and shake (rather violently) I have a clunck. Any ideas? The shocks are much better than what was on there.
    Dec 2010
    Sunset orange
    Camaro Z28 2002 LS1
    Got it, Shock R&R went well.
    Still have clunk sound from right rear.
    maybe a bearing?
    Ideas?
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    tighten control arm bolts at body mount location. Its rather intresting that the factory bolt holes on the arms are 1/2in and the body bolt holes and the bolts are like 10.9mm. I fixed this problem by drilling the body mount holes to 1/2in and getting matching bolts so now I dont have to tighten the control arm bolts to hell and back to keep the clunking noise away. Just a thought....
    phoenix
    Quote Originally Posted by JRENIGAR View Post
    Very interesting thought.
    Senior Member
    texas
    2000 formula
    Dec 2010
    Sunset orange
    Camaro Z28 2002 LS1
    Thanks JRENIGAR I'll check them control arm bolts.
    Sorry I haven't replied sooner, been a busy week and a half.
  1. front shock lower springs, shock mount mod?
    By JayTA98 in forum Suspension and Handling
    Last Post: 12-24-2011, 03:48 AM
  2. upper strunt mount (rusted nut issue) ??
    By Mr.Lee in forum Suspension and Handling
    Last Post: 11-15-2009, 09:14 AM
  3. Help: Shock mount components
    By sirenformula350 in forum Suspension and Handling
    Last Post: 08-04-2009, 10:35 AM
  4. unscrew driver side upper mount shock bolts(98' Z28)
    By paq in forum Suspension and Handling
    Last Post: 11-29-2006, 08:01 AM
  5. Upper rubber shock mount problems
    By Banshee1967 in forum General Help
    Last Post: 11-05-2006, 06:20 AM
