    Northfield, MN
    white w/ silver stripes
    2002 Trans Am WS6
    Taking out motor to swap cam?
    Just like the title reads, do you have to pull hte engine out to swap the cam or can you pull hte radiator and pull hte cam out that way?
    Member SSmoky01's Avatar
    Central,Texas
    2000 Camaro Z-28 SS
    No you do not have to pull the engine.
    KWK N NUF TheKitchenSink's Avatar
    Arlington Heights, Illinois
    2001 Trans Am WS6
    This should help...read this.
    http://ls1howto.com/index.php?article=23
    Northfield, MN
    2002 Trans Am WS6
    thanks a lot guys, that helps a ton.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    Also even though the guide says you can do it by your self. I would not recommended. Trust me on that one. I pull the radiator out by myself once and after I put the cam in I got help to put it back in otherwise I would have spend 1/2 day cussin' to try to align the tabs in from the radiator and the AC condenser.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
  1. how not to swap a motor!!!
    By bluehawk2000 in forum Almost Anything Goes
    Last Post: 08-23-2010, 09:00 PM
  2. Motor Swap
    By fast14cars in forum Internal Engine
    Last Post: 11-27-2006, 12:03 PM
  3. Help!! Taking out motor
    By JD_Z28 in forum General Help
    Last Post: 03-11-2006, 11:41 PM
  4. motor swap to ls1
    By gersh in forum General Help
    Last Post: 01-05-2006, 04:37 AM
  5. Motor Swap
    By 007_Dude in forum General Help
    Last Post: 12-18-2005, 02:01 PM
