Results 1 to 2 of 2
Thread: Motor Swap
    Alabama
    Impulse Blue
    05 GTO M6
    Motor Swap
    i am planning on doing a motor swap on a gen 3 comaro. what do you guys recomend i put in it. i would love to stay with an ls series motor or a stroker. any ideas? thanks.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    348 Sportsman LS1 Close
    SPORTSMAN SHORT BLOCK INCLUDES:
    -Polished& refinished factory LS1 crankshaft
    -Billet 6.125” connecting rods
    -Diamond Flat top Piston w/2cc reliefs or -8.6cc Boost pistons
    -Diamond Pro-select rings
    -High performance bearings
    -All Gaskets, seals and hardware for short block
    -Fully balanced/blueprinted/Finish hone w/torque plate, assembled
    $2,799.99
    SPORTSMAN LONG BLOCK INCLUDES:
    -Sportsman Shortblock
    -Custom Comp Cams Roller camshaft, Forced Induction or naturally aspirated
    -Comp Cams Lifters
    -Felpro Head gasket/bolt set
    -Double roller timing chain
    -SLP blueprinted oil pump
    -RGR, Patriot, MTI, GTP or AFR heads
    $5,499.99 w/RGR or Patriot Heads
    $5,999.99 w/GTP or MTI heads
    CALL for AFR pricing
    382 Sportsman LS1 Close
    -Billet 4.00” stroke 4340 crank
    $4,599.99
    -Comp Cams Lifters
    -RGR,Patriot, MTI, GTP or AFR heads
    $7,299.99 w/RGR or Patriot Heads
    $7,999.99 w/GTP or MTI Heads
    above can be found at speed incs website
    a few bolt ons, 379 rwhp
    11.96 @113.25
  1. how not to swap a motor!!!
    By bluehawk2000 in forum Almost Anything Goes
    Last Post: 08-23-2010, 09:00 PM
  2. HOW not to swap a motor! LOL
    By Frankthetank in forum Multimedia Section
    Last Post: 08-17-2010, 11:13 PM
  3. Motor swap ?'s
    By FORMULA7 in forum Classic Muscle
    Last Post: 03-03-2007, 10:05 PM
  4. motor swap to ls1
    By gersh in forum General Help
    Last Post: 01-05-2006, 04:37 AM
  5. Motor Swap
    By 007_Dude in forum General Help
    Last Post: 12-18-2005, 02:01 PM
