Results 1 to 2 of 2
Thread: Grind into 5th gear..
11-01-2006, 03:39 PM #1Junior Member
- Sep 2006
- New Jersey
Red- 1999 Trans Am
I've noticed sometimes when I shift real fast into 5th gear it will grind almost like a bad syncro.. it's only happened a handful of times which makes me wonder if perhaps I just didnt push the clutch in fast enough.. but only in 5th gear has this happened... Do I just suck at shifting fast or am I developing a problem?
11-02-2006, 07:49 PM #2
What your describing is generally referred to as "clash".
The noise is the result of one gearset remaining partly engaged while another attempts to turn the mainshaft. This can be caused by a number of things. incorrect clutch adjustment or binding of clutch or gearsgift leakage. Damaged or worn synchronizer blocking rings also improper gear lube.
5th gear grind
By LeadFarmer in forum Manual TransmissionReplies: 3Last Post: 01-24-2012, 07:16 PM -
grind into 3rd
By mrmarcflo in forum Manual TransmissionReplies: 1Last Post: 04-27-2011, 08:50 AM -
6th gear grind
By redbird555 in forum DrivetrainReplies: 1Last Post: 07-10-2009, 03:25 PM -
Help: Transmission Gear Grind
By taks32 in forum Manual TransmissionReplies: 5Last Post: 05-21-2008, 09:25 AM -
1st-2nd Gear Grind
By khopwood77 in forum Manual TransmissionReplies: 2Last Post: 02-02-2007, 07:25 AM
