Results 1 to 2 of 2
Thread: 6th gear grind
07-05-2009, 03:19 AM #1Senior Member
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
6th gear grind
Im looking at a 99 z28 and when I was test driving it all the gears seemed tight and fine but when I went to go into 6th it grinded just for a split second but went in fine and did so every time after. I was wondering will the tranny need a rebuild immediatley or can this be used for a good length of time. After all I dont think anyone slams 6th to be bad on the forks or synchros.
Thanks Dan
07-10-2009, 03:25 PM #2LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
Weird. Mine was doing that in 2nd gear and I was all stressing like crazy over it because I almost immediately was thinking syncros... but I flushed my tranny (it def didn't feel like it was slipping, so I figured it was a safe bet to try) and bled my clutch and it stopped. I was real low on trans fluid and had air in the clutch and it fixed my problem! Give that shot. Also, I've heard that if you're not allowing the syncros to do their job in the proper time, they will grind ... but in 6th gear, they've usually had all the time they need by then
5th gear grind
By LeadFarmer in forum Manual TransmissionReplies: 3Last Post: 01-24-2012, 07:16 PM -
grind into 3rd
By mrmarcflo in forum Manual TransmissionReplies: 1Last Post: 04-27-2011, 08:50 AM -
Help: Transmission Gear Grind
By taks32 in forum Manual TransmissionReplies: 5Last Post: 05-21-2008, 09:25 AM -
1st-2nd Gear Grind
By khopwood77 in forum Manual TransmissionReplies: 2Last Post: 02-02-2007, 07:25 AM -
Grind into 5th gear..
By 99RedTa6spd in forum Manual TransmissionReplies: 1Last Post: 11-02-2006, 07:49 PM
