10-27-2006, 12:25 AM #1Junior Member
- Oct 2006
- Houston
Rough idle / fuel smell on 98 LS1
I'm a newbie and this is my first post. I've already learned a great deal from you guys so thanks in advance for helping with this problem. Here's the scenario:
New 98 Vette, my first LS1 (70,000 miles)
-After 5 hour drive home noticed very strong fuel smell in garage.
-the car has a very intermittent miss at idle, not noticeable in gear, not present all the time
-No codes whatsoever, had unbiased chevy dealer inspect and run diagnostics prior to purchase
-great gas mileage
-Came with nasty air filter, already changed
-factory airbox keeps coming unlatched while driving
-At stop signs surrounded by fuel smell
-Power seems good, but what do I know...it's my first
-No obvious fuel leaks
My initial assessment is that it is running rich at idle. So now I ask the experts...Where should I start?
Thanks again
10-27-2006, 05:10 PM #2
Try cleaning the MAF sensor. It fixed mine.
10-28-2006, 12:06 PM #3
Also force a fuel trim relearn by disconnecting the battery and then putting the key to the on position(not start), this will drain any stored energy in the capacitors.
You clean the maf by spraying the filaments with a non-residue cleaner like contact cleaner...you can get some at radio shack.
Also check around the injectors for any fuel leaking/puddleing. It sounds like it's just running a little rich though.
10-28-2006, 12:10 PM #4Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
Is the exhaust stock or does it have aftermarket with no cats?
10-28-2006, 04:58 PM #5
Perhaps previous owner put a choppy cam in it.
10-28-2006, 05:45 PM #6Junior Member
- Oct 2006
- Houston
Resolution
Thanks for all your replies. The culprit turned out to be a fuel leak underneath the car. Since it only happens after driving, I'm guessing it is a line off of the pump. Any common failure items that can cause this? Cleaning the MAF, replacing a rotted vacuum line, and changing the plugs straightened out the rough idle issue.
11-01-2006, 11:43 PM #7
I had a problem with a fuel filter not being completely attached. I changed it and didn't get it tight enough.
11-16-2006, 05:43 AM #8JOSEY FUCKING WALES!
- Nov 2005
- College Station TX
Black- 2000 &2002 Z28
I had a problem like that once....it happened to be the back left sparkplug boot came off the sparkplug. It still made contact but barely....It was makin a really low spark and made the engine sound like crap and have a bad misfire at idle. The weird thing was that no check engine light came on either. I was thinkin had a really bad problem but I went through all the basics first....Bought new Wires and sparkplugs and when i went to reach for the sparkplug wire on the sparkplug it came right off.
I was releive it ended up being something like that....
Aparently it happens to allot of people, ive heard of 3 or 4 people having this happen to em
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 05:12 AM -
Help: rough idle
By RLamas in forum Firebird / WS6Replies: 8Last Post: 05-01-2009, 04:59 PM -
Z28 Still Has Rough Idle Wtf????
By LETHALxLS1 in forum Camaro / SSReplies: 72Last Post: 02-01-2008, 02:07 PM -
rough idle?
By 01ls1ws6 in forum Firebird / WS6Replies: 14Last Post: 02-15-2007, 06:44 AM
