Thread: witch header gasket?
10-24-2006, 10:39 AM #1
just ordered the off roead pacesetter headers and the guys at texas speed said to re use the factory gasket, can i do this or is there a different , better gasket to use
10-24-2006, 10:55 AM #2Member
- Pittsburgh
The only thing better would be a new OEM gasket.
02 TA A4
408ci - 244/250/612/622 | PRC 237 heads | FTRA |100mm lid | FAST92/92 | Kooks 1 7/8 | Hooker CB | DMH Cutout | built trans | Yank4000 | 412 motorsports tuned | stock rear:judge:
08 TBSS - Borla CB
10-24-2006, 11:06 AM #3
it's which (selection), not witch (evil lady)...lol
regardless of what brand you go with, you will want metal/copper compression fitting gaskets. those will provide the best seal for your header flanges to your cylinder heads
10-24-2006, 11:07 AM #4
Seal4Good
I am in the process of changing my headers and purchased "Seal-4-Good". The old ones (OEM) appeared to be copper and probably could have used them. The Seal-4-Good compress really well. I haven't fired it up. Maybe tomorrow evening.
http://www.percyshp.com/seal4good.html2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
337rwhp/348rwtq
10-24-2006, 05:01 PM #5
Just use metal OEM gaskets from GM.
10-24-2006, 05:25 PM #6Senior Member
- Jul 2005
- Jacksonville, FL
10-25-2006, 05:52 AM #7
just wanted to check , oh and thanks for the spelling lesson
10-25-2006, 04:16 PM #8
FelPro
The FelPros work and seal 20x better if you take the ULTRA COOPER Permatex and spread a thin bead with your fingers around port area...........
Wait 15 mins. for it to set-up then install!!!!
We have found it usually........Makes them last for multiple motor swaps......Unless the header flange in wrapped bad.
That's my 2 cents.........!!!!!Don't be afraid of the bottle!!! Be afraid of your tune!!!
10-25-2006, 05:17 PM #9
Use the stock gaskets, no permatrex.
Header Gasket
By theorangeguy in forum External EngineReplies: 14Last Post: 10-29-2013, 03:55 AM -
header gasket
By tomsws6 in forum LT1Replies: 2Last Post: 08-29-2008, 03:45 PM -
GM Header Gasket or Copper?
By DeadLifter in forum External EngineReplies: 8Last Post: 01-01-2008, 06:09 AM -
Header gasket
By jerry trans am in forum External EngineReplies: 1Last Post: 07-15-2007, 12:05 AM -
problems with header gasket
By Orange99z28 in forum External EngineReplies: 3Last Post: 08-29-2006, 08:07 AM
