Thread: GM Header Gasket or Copper?
12-28-2007, 08:30 AM #1Member
- Mar 2007
- Portland, IN
Silver- 1998 Camaro SS
Got my Pacesetters today and they sent copper gaskets with them. Thought about usin the GM gaskets and if they let go havin the copper ones for back up.
12-28-2007, 09:23 AM #2
if you have the copper ones already though why not go ahead and use them? That's what I would do. Copper gaskets used to be the preferred gasket. The stock GM gaskets are a good cheap piece though.
12-28-2007, 09:28 AM #3Member
- Mar 2007
- Portland, IN
I have copper and GM. I'm just a little leery about the copper ones though. I tried them on a Mustang before and for some reason couldn't get them to seal for nothin. Ended up usin Mr. Gasket and high temp silicone and never had a problem.
12-28-2007, 09:41 AM #4
well, if I had both sets I would probably use the GM gaskets.
12-30-2007, 03:55 PM #5
12-31-2007, 10:33 AM #6Member
- Mar 2007
- Portland, IN
Went with the GM gaskets and prayed bout 50 times for no leaks and everything turned out great.
Thanks
12-31-2007, 02:08 PM #7
I used NEW GM gaskets, even though the old ones only had 12,000 miles on them.
Was told by many to use the old ones, if they were in good shape, but I figured I could afford new ones for $30.2002 Sunset Orange TransAm 6 spd.
http://www.mustangmods.com/data/1327/dadsigpic2.jpg
01-01-2008, 06:06 AM #8
anythings better than a notorious paper gasket
01-01-2008, 06:09 AM #9
you know what? thats just the drivers side...i don't even wanna tackle the passengers yet without a friends help
Header Gasket
By theorangeguy in forum External EngineReplies: 14Last Post: 10-29-2013, 03:55 AM -
header gasket
By tomsws6 in forum LT1Replies: 2Last Post: 08-29-2008, 03:45 PM -
gasket for header install....
By 0rion in forum GTOReplies: 10Last Post: 08-28-2008, 07:19 AM -
Header gasket
By jerry trans am in forum External EngineReplies: 1Last Post: 07-15-2007, 12:05 AM
