Results 1 to 14 of 14
    Member RS_SS69's Avatar
    Denver
    Onyx Black
    2001 SS
    A4 gearing question?
    I have the 2.73 gears in my A4 2002 Z and the car rocks but seems to take forever to rap out when its pulling through the gears, it has a 3400 stall with a 2.2 STR and a cam and header back exhaust, no doubt that the car just freaking moves but would it even be beinificial to upgrade to either a 3.42 or a 3.73 gear or do you think that will hurt my performance? It is daily drivin and used at the strip as well so any help or suggestions would be appreciated!
    Cam specs??
    Car would probably love some gears.
    Denver
    Onyx Black
    2001 SS
    Cam specs??
    114 LSA .588/.588 232/232 I think that is it I have to pull it up to see!
    Sure she makes some decent power.
    That cam is wanting gears.
    Depends on what you want to do with it and if mileage matters.
    I would recommend 3.73, but you will feel a decent difference with even the 3.42.
    Denver
    Onyx Black
    2001 SS
    well i dont mind the whole mileage thing since its 5 min to work and with the bad weather coming I wont be driving it that much so I guess ill look into some 3.73s for my series 2 carrier thanks curtis!
    Denver
    Onyx Black
    2001 SS
    oh and it will be getting a 150 shot of juice for the track season next year so...
    So....
    You are telling me I might need to watch out a little?
    Denver
    Onyx Black
    2001 SS
    So....
    Uh yeah I guess you could say that....
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    gears will also be easier on your tranny, less stress on clutches
    just think of it as riddin a mountain bike, are you gonna accelerate faster in 5th or 3rd, and think how much eisier it will be on you legs
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if you are adding nitrous to the mix, get no higher than 3.73. i had 4.10 in my black car. on the bottle, i would have to shift into OD about 70 feet before the traps. with the 3.73 gears, i now go through the traps in drive (3rd) at about 6100 rpms.
    Junior Member domestic rice's Avatar
    SC
    99 Z
    If you are going to keep the #2 carrier then make sure you get the "thick" gearset. DONT get the spacer, it sucks and will be a biotch to get right.
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by RS_SS69 View Post
    How is that cam as a daily driver? Seems a bit radical for daily use.
    Denver
    Onyx Black
    2001 SS
    Quote Originally Posted by BlackLT1Z28 View Post
    It actually isnt half bad it does surge but with a little more tuning that will be fixed, as far as power with the cam and 3400 stall the car is a freak and I love it!
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    when tuned right almost any cam can become a suitable DD...ah but like i said..a very good tune
  1. Gearing question for the solid roller guys
    By cam02ss in forum Nitrous
    Last Post: 08-05-2010, 12:06 PM
  2. a4 gearing
    By Faught in forum Drivetrain
    Last Post: 07-09-2010, 02:45 PM
  3. Truck gearing question?
    By adam3566 in forum Drivetrain
    Last Post: 01-02-2008, 08:00 AM
  4. gearing question and opinion needed
    By clg82 in forum Drivetrain
    Last Post: 09-21-2007, 03:58 PM
  5. Gearing question
    By vannatte in forum Drivetrain
    Last Post: 08-19-2007, 11:52 AM
