Results 1 to 2 of 2
Thread: compression on pump gas
10-18-2006, 01:00 PM #1live fast, die young.
- santa ana
metallic blue- 1969 camaro
im getting a 350 that is 9.5:1 compression. im replacing the cylinder heads with the vortec style heads. my problem is that the way the vortec combustion chambers are designe, they raise compression. does anyone know ho much they raise the compression. and what is the highest compression i can run on pump gas 91 octane, this is goin to be my daily driver. thanks
10-18-2006, 02:47 PM #2
What's the combustion chamber volume of the new heads?
If you figure that it's too much, you could get a little thicker head gasket to lower the compression slightly.
And I don't know the exact numbers, but I know the LT1 has a 10.5:1 comp ratio and the LT4 has a 10.8:1 comp ratio on pump gas.
compression ratios and pump gas
By mark21742 in forum Internal EngineReplies: 10Last Post: 05-01-2011, 03:27 PM -
compression
By emotionalpiracy in forum Internal EngineReplies: 5Last Post: 05-30-2008, 12:16 AM -
compression
By 00ssls1 in forum Internal EngineReplies: 0Last Post: 05-28-2008, 08:18 AM -
Power Steering pump leak?! new pump or seal kit?
By JehalinTA in forum General HelpReplies: 2Last Post: 03-18-2008, 11:05 PM -
By 69camarokid in forum Internal EngineReplies: 1Last Post: 10-18-2006, 01:25 PM
