Results 1 to 11 of 11
Thread: compression ratios and pump gas
04-27-2011, 06:48 AM #1
Ok, so if my math is right on this=
4.030 bore
4.000 stroke
58 cc chamber
6 cc valve relief
Would give me 12.49:1 static compression
But with my cams intake closing at 85 degrees abdc my dynamic compression would sit at 8.22:1......
Camshaft is a comp 305 255/263 .624/.624 115lsa
This would be the perfect compression ratio for 93 octane and the most power if I am correct.
Any thoughts?
04-28-2011, 07:25 AM #2
- Dec 2005
- Laurel, Maryland
12.5:1 is too high for pump gas...better off dropping it to 11.5:1. Most tuners and builders will agree that 11.5:1 is the limit for pump gas unless you want to pull A LOT of timing to make it work, and then you're just loosing power.
04-28-2011, 10:11 AM #3
That's what I originally thought too, till I took my can into consideration.... my dcr was pretty low compared to scr.
To get 8.22:1 dcr I would be looking at 12.49:1 according to a few different calculators I was looking at.
04-28-2011, 10:59 AM #4
Just my 2cents,
Well, for shits, assuming the block is zero decked, and I gave .035" for head gasket I got about 12.75, that can change a decent amount though depending on diameter of head gasket and piston deck height. So I would say were pretty close.
12.5 Seems a little high to me on pump gas, That cam is going to call for some serious timing too. So if your planning on spinning that girl past 6500 which that cam will easily do... I would back off my compression, I would also say 11.5 is the limit for pump gas(with aluminum heads, and a great cooling system, and a spot on tune) Something that is going to be putting 600-700hp to the ground, like you I assume, is at a higher risk of detenation... so I would feel safe at 11.1 that way you don't have worry about one little thing blowing it. When an engine gets real close to the compression limits in my experiance... any thing will trash it I.E. low fuel pressure, to much timing, clogged injector, bad tune, high temp, free rev, ect...
Also it is very heard to calcuate dynamic compression, to do it accurately you would need to know the exact velocity of air through your exact intake, heads, headers, efficiency within the cylinder ect. there is alot of variables to dynamic compression, so I just stick to static calcuations.
Hope that helpsRUDE, CRUDE, AND SOCIABLY UNACCEPTABLE.
04-28-2011, 02:47 PM #5
Looking at spinning to or past.7,500rpms.... Il determine peak shift points and fuel cut rev limit when I see where it falls off power on a dyno
04-28-2011, 03:02 PM #6
Thats going to be a mean, SOB
04-28-2011, 04:17 PM #7
04-30-2011, 02:26 PM #8
- Sep 2010
- Ohio
midnight blue- 1998 Pontiac trans am
What intake are you going to use to spin the motor that kind of rpm's?
04-30-2011, 05:19 PM #9
04-30-2011, 07:47 PM #10
- Sep 2010
- Ohio
Looks good, I haven't seen anyone post results with that intake yet. Curious to see how it performs. Did you have to cut much out of the cowl to get it to fit?
05-01-2011, 02:27 PM #11
MM6 Ratios
By johnfin in forum Firebird / WS6Replies: 2Last Post: 06-18-2013, 09:44 AM -
weight to hp ratios
By FutureWS6 in forum Firebird / WS6Replies: 8Last Post: 04-12-2010, 10:37 AM -
Compression ratios
By 98redconv in forum Internal EngineReplies: 22Last Post: 12-08-2008, 12:34 PM -
compression on pump gas
By 69camarokid in forum External EngineReplies: 1Last Post: 10-18-2006, 01:47 PM -
By 69camarokid in forum Internal EngineReplies: 1Last Post: 10-18-2006, 12:25 PM
