Results 1 to 20 of 20
    US
    burnout=clutch pedal got stuck
    ok so ive owned the TA for about 2 weeks now, and i am good on a stick now, so i did my first burnout today..my god it was awesome..i revved it to 4k and then dumped clutch, it was soo awesome, rev limiter bouncing, swirving all over the place, then all of a sudden when i put clutch back in to switch to a dif gear, it wouldnt go into ANY gear, so i coasted to the side of the road, turned off car, let foot offof clutch, and it woulndt come up? so i pressed the clutch in and it let off, i then started car and everytiong was fine again, why did that happen?
    The stock hydraulics suck.
    Probably needs a new slave cylinder at the least.
    Member DriveV8Faster's Avatar
    Long Island, NY
    Something kinda similar happened to me once in an A4 LT1. I was doing a sweet ass burnout and then the car would not go over 2000 rpms. Then I shut it off, thinking I totally fucked something up and when I turned it back on, everything was back to normal.
    Member Thorazine Shuffle's Avatar
    Indianapolis,Indiana
    2000 WS6 A4
    You might want to be careful about "bouncing it off the rev-limiter" or your burnouts may become very expensive!!!
    just my.02
    Future Super Trooper Mr. CarelessAndImprudent's Avatar
    Rolla, MO
    '69 Camaro
    You might've done something to the pressure springs in your clutch disc
    Member 6sw00's Avatar
    N.Y
    2000 trans am ws6
    i would never bounce the limiter.. read in a mag that if the engine goes over 6200 or so, ur gunna be in trouble.. the ls1 isnt made for that.
    Junior Member msb304's Avatar
    wv
    2001 t/a ws6
    Sounds like your pressure plate is wearing out. You probably collapsed the diaphram. I have seen a weak or cheap pressure plate actually suck the clutch pedal to the floor at extreme rpm`s.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Sounds like the pressure plate to me. Clutch disk is not releasing for some reason and sticking to the flywheel
    Kannapolis
    I have the same problem, although I don't bounce it off the rev-limiter or do burn outs that much. Its jsut that in the higher rpms the clutch sticks to the floor, I have to pop it back out with my foot. So everyone is saying that its the pressure plate, not the slave cylinder? Both, what is a slave cylinder...basically...what do I need to buy to fix this?
    Aug 2000
    Indy
    drill mod
    Kannapolis
    drill mod?
    Apr 2002
    San Jose
    slave cylinder is on the input shaft and it pushes on the diaphragm of the pressure plate and it may be the reason your clutch isn't releasing. One or the other, the slave will be a problem as well
    Edison, New Jersey
    2001 WS6
    Same thing happened to me. I have an 01 ws6 with spec stage 3 clutch and upgraded hydraulics. Clutch got stuck a few times under normal driving. Had to pop it out with foot and it hasnt acted up since.
    Member lrader99's Avatar
    NW Georgia
    flat black
    that damned hydraulic line from the master to the slave has a restriction in it...hence the drill mod...burnouts heavy shifting is known to cause this problem...ive seen many factory bottom ends good to 7200...but then again ive seen them blow just off idle...so you never knwo
    Kannapolis
    so I only need a new hydrolic line? I'm sorry, but i have no clue of where to start
    Master Mechanic Jims455's Avatar
    Jun 2006
    Crowley Texas
    '02 WS6
    Quote Originally Posted by Racquetballryan View Post
    Purchase a Helms service manual and search all the FAQs on as many LS1 and TA/F bod boards as you can and then start wrenching pvt.
    Also, you may want to learn to spell...
    Kannapolis
    My fault, its late and I'm not paying too much attention, I appreciate it though.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by Jims455 View Post
    not needed this isn't Englishgrammar&spelling.com at least i dont think it is
    Shepherd, Michigan
    98' trans am
    but yea deff dont bounce of the limiter..limiter cuts fuel/runs lean..high rpms+running lean=fucked
    Kannapolis
    Smile
    Stop with the replacing!!!!!
    I just fixed my cars clutch pedal for $9.56
    Its just the clutch fluid, go take a look at your clutch fluid right now. I guarentee you it will be a dark mud color with a bunch of globs in it. This is the way mine was (I'll post up pictures later) and it was crazy! Here is a step by step link as to how to do it.
    http://forums.corvetteforum.com/show...t=clutch+floor
    its easy, it took maybe 5 minutes and now Its like I have a new clutch.
    I had to flush mine around 5 times it was so cantaminated. Good luck, and then afterwards go enjoy some real burnouts with no sticky clutch
  1. Burnout at the track causing hard clutch pedal.
    By Kramsdell in forum Manual Transmission
    Last Post: 11-18-2011, 06:31 PM
  2. Ouch...Gas pedal got stuck
    By Joe00SS in forum Camaro / SS
    Last Post: 03-26-2011, 01:54 PM
  3. Clutch Pedal Pressure and Smelly Clutch
    By race5050 in forum Manual Transmission
    Last Post: 01-06-2010, 05:37 PM
  4. stuck gas pedal
    By 2000 ss in forum General Help
    Last Post: 04-15-2008, 07:10 PM
  5. Light Clutch Pedal (New Clutch)
    By Rhinohuey in forum Manual Transmission
    Last Post: 09-22-2007, 08:51 PM
