Thread: Various Bolt torque levels
10-15-2006, 12:47 PM #1Member
- Newport, Mi.
red- 1999 Camaro SS
There use to be an article containing torque values for nearly every bolt in the LS1 engine on this site. I did a search and could not come up with it.
For now, I need the torque value for the rocker arm studs, intake bolts, and the cylinder head bolts (both the GM stock head bolts and ARP head bolts).
TIA. Doc'99 Camaro SS; 6-spd, LS2 402 stroker short block, PP stage 3 heads, GMS MAF, 244/248 cam, FLP headers, Borla catback, 4.10 gears, LS6 intake, 39#/hr injectors, Pro 5.0 shifter, subframe connectors, Comp Cams 1.85 rr,
Best ET: 12.23sec (2.000sec 60'), trap spd:117.5mph, with the LS1 engine.
10-15-2006, 01:05 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't know if this'll help - for the '98. http://www.ls2.com/boggs/torques/eng...tm#Application
10-15-2006, 01:19 PM #3
10-15-2006, 03:09 PM #4Member
- Newport, Mi.
red- 1999 Camaro SS
Thank you both of you, that will do it !!!!!!!
Head Bolt Torque Advice
By swifty in forum Internal EngineReplies: 5Last Post: 11-09-2013, 05:51 AM -
Intake bolt re-torque ?
By km346 in forum External EngineReplies: 1Last Post: 04-28-2010, 08:45 PM -
Question: LS1 Head bolt torque settings
By Gav in forum General HelpReplies: 6Last Post: 06-01-2008, 02:59 AM -
arp head bolt torque
By RallyBoy in forum LT1Replies: 0Last Post: 12-16-2007, 03:57 PM -
Rod Bolt Torque?
By white lightning in forum Internal EngineReplies: 2Last Post: 05-27-2007, 06:39 PM
