Thread: Head Bolt Torque Advice
11-08-2013, 07:16 PM #1Junior Member
- Dec 2005
- colorado springs, co
maroon- 2000 Z28
Hi. I am putting AFR 215 heads on my 2000 Z28 and just finished the 3 stage head bolt torqueing process from LS1HowTo. This did not go well for me and I ended up with about 4 or 5 of the M11 bolts well short of the stage 3 90 degree turn...like in the 40-50 degree of turn neighborhood. All stage 1 and 2 turn worked ok. These bolt heads are buggered and no further torqueing is possible.
I am trying to decide whether to complete the assembly or back out all of the bolts and start over with new bolts and gaskets. I used ARP bolts and second time around I think I might have better luck with OE bolts as they have a larger hex head (15 mm) than ARP (13 mm).
What is your opinion as to whether my several under torqued head bolts will cause a problem or do you think that I am close enough to spec.
Thanks so much in advance.
11-08-2013, 07:54 PM #2Senior Member
- Apr 2010
- Alabama
What did you torque the arps to? It was pretty simple for me and there were no problems. I torqued all bolts in the correct sequence to 25, then 50, and then 75. I had no issues doing it this way. For arps there are no degree specifications since they are not torque to yield bolts, all you have to do is do the torque sequence. Also did you use their assembly lube that comes with the bolts?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
11-08-2013, 08:23 PM #3Junior Member
- Dec 2005
maroon- 2000 Z28
I did not know Arps are not tty. I thought they were same as OE, just prettier. I am using ls1howto as a guide. He says to torque, in correct sequance, to 22. Then on second pass one 90 degree turn and the on third pass another 90 degree turn except short M11s a 50 degree turn. I am sure they are torqued well beyond 75. Yes, I did use the lube. Crap I think I have missed something. Wow, what to do now.
11-08-2013, 08:36 PM #4Senior Member
- Apr 2010
- Alabama
I would just loosen them back up and torque them to 22 or 25 (I did 25), 50, and then 75 in the proper sequence. Then you are done. No arp bolts or studs are torque to yield if they were you would have to throw them away after removing them since ttyl bolts are 1 use only.
11-09-2013, 04:27 AM #5Junior Member
- Dec 2005
maroon- 2000 Z28
Thank you for the information and advice, 98transamws6.
11-09-2013, 05:51 AM #6Senior Member
- Apr 2010
- Alabama
Glad to be of help.
Question: LS1 Head bolt torque settings
By Gav in forum General HelpReplies: 6Last Post: 06-01-2008, 02:59 AM -
Advice Please on Torque Converters
By 346ci in forum Automatic TransmissionReplies: 15Last Post: 01-25-2008, 11:46 PM -
arp head bolt torque
By RallyBoy in forum LT1Replies: 0Last Post: 12-16-2007, 03:57 PM -
Rod Bolt Torque?
By white lightning in forum Internal EngineReplies: 2Last Post: 05-27-2007, 06:39 PM -
LS2 Cylinder Head Bolt Torque?
By brundag5 in forum General HelpReplies: 1Last Post: 01-04-2007, 05:56 AM
