    Hattiesburg,MS
    Navy Blue
    2001 Camaro z28
    Tune after headers and no cats install?
    I was wondering if i have to do a tune after i install headers w/02 sensor sims. and no cat y-pipe.
    I am getting ready to do this install soon.
    i will also do a plug and plug wire change while i am at it.
    also is there any header gaskets (copper, aluminum, etc) that can be recommended.
    Thanks
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    tunes are your best friend(s). Highly recommended that you do if you want to see the full gians out of your mods.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Like said above too see the most gains you will want a tune but you dont need one. It will run a lil rich but not too bad. Your sims will keep your ses light from coming on so you should be good to go. Dont use cheap paper gaskets, personaly i used stock gm gaskets.
    J
    St. Louis
    02 z28
    Quote Originally Posted by sunsetorangess View Post
    J
    yep yep, run a little rich, tune will help out a lot, i did the same and used the stock gm gaskets..which are probably the best gaskets you are going to find for your car. I recommend running bosch corvette o2's instead of sims, because sims seem to malfunction from time to time and the vette 02's are the longer wires that will fit fine.
    Tony
    02 Camaro Z28
    UltimateSR <-- Join it!
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    From what i read on LS1tech the computer is supposed to monitor the AFR and keep the fuel at 14.7, the only time you would run rich or lean is at WOT. But if you have it dyno tuned the can adjust your fuel trim and then you will see maximum gain from headers and exhaust you put on it but tune is not totally necessary. your car isnt stupid, it knows where to keep the fuel trim at when idling and during normal driving what not. Dyno tune recommended but not necessary to keep car running. If you plan on doing anymore mods like heads cam and intake in the near future then i would just wait on the tune, that is what i recently decided to do after studying up on the topic on here and on www.LS1tech.com Hope you enjoy your new headers and exhaust.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    Aug 2006
    San Diego, CA
    1999 T/A
    you want to get a tune after doing a headers swap. i would only wait if you plan on doing more mods in the very near future.
    MS4 Camshaft, Doulble Valvespring, Chrom Moly Hardened Push Rods, QTP LT Headers, 3" Custom Strait Pipes w/ Single Chamber Flowmasters Dumped,
    !AIR, !EGR, !CAGS
    Ross
    Virginia
    2001 Camaro z28
    Yeah when I get headers im gonna most likely get a tune, cause i can get one for 350$ that i know will be good.
    You might just want to see what the car runs like after you install your headers.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    tune it after the headers, i did and was glad i did at the time.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Car RamRod 98Camarod's Avatar
    Feb 2006
    Goose Creek, SC/ NWS
    Green
    1998
    I havent tuned mine yet LT ceramic pacesetters and it seems to be fine. Im sure I would benifit from a tue, but Im gonna throw a stall on there and would rather tune it after that. When you get it tuned you can tune out the rear o2 sensors so you dont need the sims after that.
  1. Question: Need a tune after removing cats on modded car?
    By devildogws6 in forum Computer & Tuning
    Last Post: 01-23-2013, 09:39 AM
  2. Cats and tune
    By karpetcm in forum External Engine
    Last Post: 12-03-2008, 10:22 PM
  3. Question: Diablo or Shop Tune & Should the Cats be Removed
    By The Silver Goat in forum GTO
    Last Post: 04-19-2008, 03:17 AM
  4. Should I Pay for Install and Tune for LT headers?
    By GottaHaveLS1 in forum External Engine
    Last Post: 09-14-2006, 12:43 PM
  5. which cats for my headers install?
    By snake_skinner00 in forum External Engine
    Last Post: 03-25-2006, 05:30 AM
