Results 1 to 1 of 1
04-19-2008, 03:17 AM #1
Diablo or Shop Tune & Should the Cats be Removed
Here's the Setup: long-tube headers with cat deletes, a Cold Air Intake and a pair of 1 chamber mufflers. This is a two part Question:
Part I
If the cats are removing and I do not supercharge or installing a turbo I've removed a significant amount back pressure. I know there's a ratio between back pressure and torque. Additionally, the exhaust valve springs are set with a specific amount of anticipated back pressure by GM. Thus removing back pressure sets me up to slap the $hit out of my exhaust valves or possibly both sets of valves?
True or False
So I'm thinking do not remove my cats unless I mechanically inject air to create back pressure.
Part II
Trying to tune it with a Diablo with the set up listed above will not work.
I should take it to a tuner or put the cats back on with sensors to use a hand held?
I know the PCM is looking for that mvh reading and if it can't find it it appears to default to throwing a ton a gas to avoid a lean condition.
Sarge - what are your thoughts?
Mind you this is not my set up. Another individual on this board is struggling to tune his goat and I think what I've laid out above is why...
Diablo Tune for 04 GTO
By surfinjoe in forum GTOReplies: 4Last Post: 06-08-2010, 03:58 AM -
Cats - able to be removed??
By GungHoPopsicle in forum External EngineReplies: 12Last Post: 12-16-2009, 07:54 AM -
Removed cats off friend's 06 GT...
By Aetos in forum Multimedia SectionReplies: 11Last Post: 12-09-2008, 12:10 PM -
Question: Diablo Tune LOOK PLEASE!!
By pmolina0436 in forum GTOReplies: 26Last Post: 09-17-2008, 07:49 PM -
Handheld Tune?shop Tune? software running on my laptop tune?on my SS
By showtimesteele99SS in forum Computer & TuningReplies: 4Last Post: 04-09-2007, 05:31 AM
