Thread: spark plug shot out of head
10-11-2006, 03:38 PM #1Junior Member
- ohio
red- 1998 camaro z28
My spark plug shot out of my 98 camaro z28, now it will not thread, in what can I do, to avoid paying for a new head?
10-11-2006, 04:56 PM #2
are there any threads left? if so, you might be able to tap it.
10-12-2006, 09:26 AM #3Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
http://www.timesert.com/html/sparkplug.html
I would still pull the head to do this job
I believe Helicoil makes inserts for spark plugs too
10-12-2006, 02:33 PM #4
I stripped one of mine while doing LT install, and was able to fix it w/o removing the head. I had a friend of mine ( who works in a shop) bring in a piece that u screw into the the sparkplug slot to re-thread it, worked very well. But, be very careful not to leave any metal shavings in there. It could possibly scratch ur cylinder wall, and although u wouldnt think so this can be very bad. We just stuck an air compressor hose in there to blow it all out, then we manually cranked the cylinder up, using the crank pulley, and shot more air in there just to make sure it was all out.
10-12-2006, 08:39 PM #5
yep, helicoil's or re-tap.
10-13-2006, 03:39 PM #6Member
- Aug 2006
- NC
mystic- 95 LS, yes it says LS
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 02:50 PM -
spark plug shot out of head 2nd time
By jsherman in forum General HelpReplies: 9Last Post: 04-09-2008, 12:59 PM -
spark plug help
By bobbert350 in forum General HelpReplies: 2Last Post: 04-21-2007, 05:38 AM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 10:01 PM
