Results 1 to 14 of 14
Thread: overdrive
    Member luciangage's Avatar
    tennessee
    94z
    overdrive
    i have a 94 z auto. i bought the car a few weeks ago and it had no overdrive. ireplaced it w/ a used one but it was no good. i decided to let my freind rebuild the one that was in the car. he is going to school for mechanics and is doing it there. i bought the kit from tci that has the exact same parts as their street fighter kit we put it back in and a shift kit. car shifts hard in a good way but still will not go into overdrive. this is my first trans experience so any ideas will be greatly appericiated
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    Im assuming you have a 1994 z28 ?
    Ok in the 4l60e there could be several reasons for no fourth , First get it scanned for codes and then let everyone know what they are .
    performabuilt
    tennessee
    94z
    it is a z28.2 codes#59 trans temp. circut high and #90 tcc enable fault(qdm) thanks
    SUGAR LOAF PA
    blue
    2000ss
    trannsmission will not go into overdrive as long as those codes are there either will put it in hot mode and disallow od ,Also are you sure its a 94 trans?
    performabuilt
    tennessee
    94z
    what causes these codes? sensors? how do you test? do i need a trans range pressure switch assembly? pressure control solenoid? what causes hot mode is there a solenoid for od? i vve got no idea about this stuff. im trying to learn thanks for being helpful and responsive
    tennessee
    94z
    oh yeah car had reman trans in it when i bought it so car is 94 trans ??? it this a factor?
    SUGAR LOAF PA
    blue
    2000ss
    Well the codes could be real codes caused but overheating due to tcc not locking , Or they could be ghost codes from a bad trans range presure switch , thats the hard part determining which , A technicial with a good scanner could easily make that determination by reading the data stream to see whats actually happening , If i was gonna guess though I would go with range presure switch ,
    performabuilt
    tennessee
    94z
    so go ahead and replace it?
    tennessee
    94z
    ok that didn't work so now what?
    SUGAR LOAF PA
    blue
    2000ss
    wait a minute I just remembered something I ran into a couple years ago , We had a 1994 z28 come to the shop to have the unit replaced , So we replaced it with a unit built non pwm for a 1994 after we built it we had no fourth a quad driver failure and a trans temp sensor lockup code, just like yours ,
    The solution was to put the original transmissions internal wiring harness and solinods on it .After doing some research I learned a couple , under the dash we found there was not only a gm1 plug but and obd2 as well though it gave the obd1 gm1 code numbers and the obd2 plug didnt work ,
    to make the tranny work we had to use the wiring harness and solinods specifically the pwm solinoid from a 1995 year , Is there a prndle switch mounted to side of transmission where the linkage goes , black thing with two plugs on it ?
    performabuilt
    tennessee
    94z
    no i dont have that plug and i dont have the original wiring either. however i do have the motor and trans out of a 94 caddy. this is what i was going to build for my car. i could use the wiring harness, solenoids, and computer on my car? iwould have to use lt1 edit or something but if you think it might work i can try it. thanks. oh yeah i bought an atsg manual so maybe this will help
    SUGAR LOAF PA
    blue
    2000ss
    you do not need to swap out the car harness just the transmissions internal harness and solinoids .
    tennessee
    94z
    and the computer?
    tennessee
    94z
    changed out the trans wiring and solenoids nothing different do i need to put the other computer in the car?
  1. Sometimes not in overdrive on the highway. How come?
    By SiskMan in forum General Help
    Last Post: 11-06-2014, 05:31 PM
  2. Overdrive?
    By AfterYou in forum Automatic Transmission
    Last Post: 09-25-2010, 09:10 AM
  3. Question: overdrive pulleys
    By DARK PHX in forum V6
    Last Post: 07-14-2010, 11:26 AM
  4. No overdrive
    By cm1273 in forum Automatic Transmission
    Last Post: 03-23-2010, 04:40 PM
  5. Overdrive vs. no Overdrive
    By Johny Bee O in forum Drivetrain
    Last Post: 10-13-2008, 01:08 AM
