Thread: Overdrive?
09-19-2010, 03:55 PM #1I Drive A 95'
- Aug 2009
- Granbury, Texas
01' Firebird Pewter- 98' Trans Am Black
Overdrive?
When you are using the manual 1,2,3 and D gears, Will they hurt the motor in anyway if shifted correctly, overtime will it cause damage?
09-19-2010, 04:05 PM #2
1.You can't shift faster than the computer
2. You can hurt the trans it by downshifting
3.Only reason I ever manually shift is to hold it in gear during autox
09-19-2010, 05:05 PM #3Senior Member
- Apr 2008
- Madison, WI
The computer won't let you damage the motor by downshifting but as stated there isn't any reason or advantage to shifting the transmission yourself.
If you're traveling down a mountain road, you could use 2 to provide some engine braking so you don't have to ride your brake pedal the whole way down the mountain and burn up your brake pads.
09-20-2010, 02:35 PM #4I Drive A 95'
- Aug 2009
- Granbury, Texas
thanks! it was just a personal knowedge kind of thing, always been in the back of my mind
09-25-2010, 09:10 AM #5
There is an advantage to shifting the trans on your own and its to keep from swapping ends lol. With my 383 and street tires I manually shift it because if I didn't the thing would be in third and backwards before I knew it. Other than that this is a debate that has lasted as long as the trans it's self. For a stock setup yes put it in drive and go. If you tring to launch on street tires, lol do the 1 to 2 on your own and let the computer shift 2 to 3. Just under stand the hanging rpms are not good for the engine unless you built it for that.
Sometimes not in overdrive on the highway. How come?
By SiskMan in forum General HelpReplies: 6Last Post: 11-06-2014, 05:31 PM -
Question: overdrive pulleys
By DARK PHX in forum V6Replies: 4Last Post: 07-14-2010, 11:26 AM -
No overdrive
By cm1273 in forum Automatic TransmissionReplies: 9Last Post: 03-23-2010, 04:40 PM -
Overdrive vs. no Overdrive
By Johny Bee O in forum DrivetrainReplies: 2Last Post: 10-13-2008, 01:08 AM -
overdrive
By luciangage in forum Automatic TransmissionReplies: 13Last Post: 10-22-2006, 08:24 AM
