Results 1 to 10 of 10
    Bethlehem
    blue metallic
    2000 trans am WS6
    clutch questions...
    hey im pretty new to f bodys... i got an 00 WS6.
    im looking at clutches... tell me whats good to get and not exspensive.. heres my info..
    im only planning on doing 4.10 gears, exhaust but no headers, lid and tune basicly just that. and occasional track. mabye 4 times a year mabye? with prolly about 5 runs or so... i was looking at spec 3 clutches but im not planning on making alot of power. i dont want to put a styock unit in either.. i would liek a little harder pedal also but doesnt have to.. let me know whats good.. whats the best bang for the buck... thanks!
    tony
    Bethlehem
    blue metallic
    2000 trans am WS6
    anyone?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    um spec 3 ...spec 3 ..spec 3 ..your not going to spend less then 350 for a clutch worth anything period..but spec stage 3 is were its at..there are ton! of threads that will talk about clutches...oh z06 clutches are good alternitives too
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    Bethlehem
    blue metallic
    2000 trans am WS6
    wel what about spec2 or a spec 1 i dont plan on making much power more then stock... you still think spec 3 is the way to go?
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by Labukas19 View Post
    yea i heard the spec2s have been known to give out before the "rated" amount...um try the z06 clutch..might be a lil cheaper but z06 or spec3 is the only way too go.
    Bethlehem
    blue metallic
    2000 trans am WS6
    where can i get a good deal on a spec 3 clutch? also what about my hydraulics? will i be fine with the origanal stuff?
    Shepherd, Michigan
    98' trans am
    check out our sponsors ..like summit racing and ws6store. um you need to upgrade the hydraulics. i'm pretty sure gmparts direct will have them, its the 2001-2002 hydraulic system hope this helped
    Bethlehem
    blue metallic
    2000 trans am WS6
    ive heard of doing that.. whats the purpose? what if i just keep my original hydraulics... also is it just the slave cyl. i would need?
    Shepherd, Michigan
    98' trans am
    i'm deff no m6 expert..but your slave and master would be replaced, the 01-02 fixed problems with pressure i believe, but i know that everyone swamps it becuase it helps save your tranny/clutch.
    Bethlehem
    blue metallic
    2000 trans am WS6
    ohh well i dont need the clutch now so i guess i got some time to save! i was just looking ahead! thanks for the info so far tho!
  1. Some Clutch Questions
    By Naaman in forum Manual Transmission
    Last Post: 06-05-2011, 04:08 PM
  2. clutch questions
    By unibuga in forum Manual Transmission
    Last Post: 08-27-2010, 03:35 AM
  3. Clutch questions
    By zoomclutch in forum Manual Transmission
    Last Post: 01-06-2009, 05:25 AM
  4. Ls7 Clutch Kit Questions
    By Justin93 in forum Manual Transmission
    Last Post: 08-14-2008, 11:58 AM
  5. Help Clutch Questions???
    By zlizard in forum Manual Transmission
    Last Post: 05-14-2007, 04:33 PM
