Results 1 to 20 of 27
    Member unibuga's Avatar
    Aug 2010
    bacliff,TX
    blue
    clutch questions
    ok so i have a 99 T/A with the 6 speed ....basicly when i wind it up hard when i hit the clutch it still feels like its grabbing a little and it wont let you shift fast at all ...ive heard of this "drill" mod? could that be the issue....and what is the skip shift light for? and why is there a part to get rid of it? im new to this car so plz help
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Drill mod is basically only for a "sticky" pedal problem.
    Skip shift light is an "economical" feature car manufactures added which forces the driver to shift from 1st gear to 4th gear. It works off both speed and engine RPM I believe. You will notice once you hit a certain speed or RPM, the skip shift light will turn off which allows you to shift directly from 1st to 2nd gear.
    Aug 2010
    bacliff,TX
    blue
    so do you have any idea on my clutch still feeling like its grabbing when close to redline? its almost impossibe to shift quickly at all making it slower also
    i realize im posting a lot of threads but im new and just have alot of questions
    Don't worry about asking questions, that is what this site is for
    I am not understanding what you are describing exactly. Are you saying that your pressure plate on your clutch is "not" disengaging from the flywheel? You are saying "grabbing", but that is what the clutches job is. It should constantly be engaged (pressure plate to the flywheel) as long as your clutch pedal is up.
    Aug 2010
    bacliff,TX
    blue
    Like when Im at about 6000 rpm and I depress the pedal I will here the clutch half way Grabbing and it won't let me shift for a sec or two....almost like its not completely disengaging
    Coral Springs, Fl
    Sunset Orange Metalic
    Look up info on the Tick Master Cylinder
    pushes more fluid than stock and is supposed to fix your issue
    Aug 2010
    bacliff,TX
    blue
    yeah i was thinkin it was just a lack in pressure
    Coral Springs, Fl
    Quote Originally Posted by unibuga View Post
    before you do anything check the clutch fluid. could be old and dirty fluid
    Aug 2010
    bacliff,TX
    blue
    I checked it and its not low....its my first standard so Idk if its old or dirty
    May 2010
    Bentonville, AR
    2002 Camaro SS LE
    if its black, its old and dirty.
    Aug 2010
    bacliff,TX
    blue
    its dark now ill check it tomorrow....should it be clear? and if its old will it make a big difference?
    If it is black, change it. Dirty versus clean...
    http://www.google.com/imgres?imgurl=...w=1024&bih=572
    Aug 2010
    bacliff,TX
    blue
    yeah ill have to try that first
    May 2010
    Bentonville, AR
    2002 Camaro SS LE
    wow, great info. what better way to show then in a picture. im gonna check mine tomorrow too.
    Aug 2010
    bacliff,TX
    blue
    so to go about changing it do i do the same as the post you showed me?
    May 2010
    Bentonville, AR
    2002 Camaro SS LE
    i've also heard, or read that you cold just syphin out what is in the resivour and add fresh?
    Never heard of that. Everyone here swears by the Mityvac method. It takes little to no time and is the only way to do this hands down.
    Aug 2010
    bacliff,TX
    blue
    still not sure how that little vac thing works
    It is a vacuum...it sucks it out.
  1. Some Clutch Questions
    By Naaman in forum Manual Transmission
    Last Post: 06-05-2011, 04:08 PM
  2. Clutch questions
    By zoomclutch in forum Manual Transmission
    Last Post: 01-06-2009, 05:25 AM
  3. Ls7 Clutch Kit Questions
    By Justin93 in forum Manual Transmission
    Last Post: 08-14-2008, 11:58 AM
  4. Help Clutch Questions???
    By zlizard in forum Manual Transmission
    Last Post: 05-14-2007, 04:33 PM
  5. clutch questions...
    By Labukas19 in forum Drivetrain
    Last Post: 10-09-2006, 12:29 PM
