Thread: power loss
    Junior Member docsmopar's Avatar
    Lodi,Ca. U.S.
    1984 camaro z/28 H.O. 5.0
    power loss
    Hello everyone! Maybe someone has had this problem before.Car is a 1984 camaro Z/28 5.0 H.O. 5 spd.,which now has a 5.7.has Jet chip.Problem is extreme loss of power when flooring the gas pedal.makes the quadra bog sound,but not a bit of get up and go.otherwise idles and runs fairly good.The person who put this motor in,5.7 now,with 5.0 H.O. heads,did a number on the wiring it seems, and even left the knock sensor off the motor and swaped the 160 degree thermostat that's needed for the Jet chip, for a 195 degree.well i fixed all that,and isn't getting hot anymore.checked fuel,ESC,knock sensor circuit retarding like it should,replaced ECM and used the same Jet chip from previous ECM,thinking the ECM wasn't advancing the timing,or was advanced all the time,which is how it acts.plug gap and cap and rotor,wires all good. One question I have is, would the pickup coil or mogule in the distributor or even the ignition coil cause this kind of behavior? Any and all input will be greatly appreciated.
    Docs Mopar
    ky
    99 camaro
    I had the same problem once with a 350 TPI, found that i left a ground wire off on the back of the drivers cylinder head. Put the ground wire back on and the car came to life.
    just my .02 cents
    Lodi,Ca. U.S.
    I'll check the left over wires back there .you never know,I might have missed one. Thankyou very much for your input,it's always greatly appreciated
    Lodi,Ca. U.S.
    Well,all grounds are fine, and none left disconnected.Idle has now worsened.any help is greatly appreciated,thankyou
  1. Help: Power loss
    By davidz28 in forum Camaro / SS
    Last Post: 09-11-2010, 09:00 AM
  2. How much power loss ?
    By karpetcm in forum Computer & Tuning
    Last Post: 03-22-2010, 02:22 PM
  3. Loss of power
    By 99RTA in forum General Help
    Last Post: 05-19-2009, 06:52 AM
  4. Help: Power loss
    By BIG GUNS in forum Internal Engine
    Last Post: 10-20-2008, 01:44 PM
  5. is this why i have power loss???
    By 02sscamaro in forum General Help
    Last Post: 09-13-2007, 02:15 PM
