09-16-2005, 10:46 AM #1ls1freakGuest
how do you replace turn signal lever
I bought the new lever and just don't know how to replace if any one can help .
thanks steve
09-18-2005, 07:45 AM #2
your probably gonna have to remove the 2 halves that go around ur steering column which is normally about 4 or 5 screws on the bottom, ull need a small long screwdriver. then it should be pretty accessible. jus take it apart youll figure it out.
09-19-2005, 11:12 AM #3
- Sep 2005
- NY
Black- 1999 Chevrolet Camaro Z28
Originally Posted by 310stanger
I looked into this while researching if I should swap out the turn signal lever with a C5 one or a caddy one that has flash to pass in it. (a member here did it a long time ago before the board fu(ked up and went in suspense for a while.
It involved in disconnecting the steering linkage under the hood, then dropping the steering column, pull it out a lil while still in the car, and then slide the shield that goes around the steering column (the one where the starting cylinder is in) and acess the turn lever, which also involves drilling out 2 rivets and puttin in the new one with screws and tighted with a nut.
Not worth it unless it's broken off and needs to be replaced for real.
This will cost the same as to do a key cylinder change from the broken PASS KEY II wires inside of it. $300!
01-04-2006, 05:17 AM #4
- Sep 2005
- Russiaville, Indiana, United S
Sunset Orange- 2001 Z28
This just makes me hate that ancient turn signal lever even more.
I remember having one on my old '85 Olds Delta 88. That thing burned up in my office parking lot. Of all the cost cutting measures I wish they'd have skipped this one.
01-04-2006, 04:34 PM #5ls1BrownBootsGuest
Originally Posted by ls1freak
Turn signal lever....
By Ws6islife in forum General HelpReplies: 5Last Post: 12-05-2011, 11:53 AM -
Turn signal lever crappy
By Cutlass in forum General HelpReplies: 23Last Post: 06-04-2008, 02:24 AM -
Turn Signal lever problem
By squeals99 in forum LT1Replies: 5Last Post: 12-02-2007, 05:31 AM -
Turn Signal Bulb Replace?
By wnmech in forum Firebird / WS6Replies: 18Last Post: 07-15-2007, 08:00 AM -
broken turn signal LEVER
By speede in forum General HelpReplies: 1Last Post: 09-26-2005, 09:28 PM
