Results 1 to 18 of 18
Thread: Monsoon Volume problem
09-21-2006, 04:51 AM #1
- Mar 2006
- Ann Arbor
Black- 2002 WS6
When I first touch the volume control knob and turn it counterclockwise in my 2002 WS6, for some reason the volume goes up at first (slightly), and then down like it is supposed to??- EXTREMELY WIERD. Any help would be appreciated.
J.R.
09-21-2006, 06:20 AM #2
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
Once again the POS Monsoon system proves how un-reliable it is. Next thing you know the lights will start to fail, or your display will go haywire or it will refuse to play CDs or etc. etc. It's either time to replace it or go with a much higher quality after-market HU.
09-21-2006, 03:56 PM #3
When I still had my Monsoon HU it had a feature that made the volume go up when you accelerated and went down when you slowed up. Maybe that's what your talking about...
09-21-2006, 05:02 PM #4
- Sep 2006
- california
red- 2002 Trans Am WS6
either that or just get one off the for sale listings, sorry, I like the steering wheel controls better than having em there and not being able to use it, you can pic one up for bout 50 bucks
09-23-2006, 08:37 AM #5
- Mar 2006
- Ann Arbor
Black- 2002 WS6
Monsoon problem
Mike
I know what feature you are talking about as far as the acceleration and braking. I had that same feature on my 98 Z28 (I forget what that is called), but that's no what Im talking about. Thanks for the help anyway.
My steering wheel controls work fine as far as turning the volume up and down, its just the damn volume-knob on the deck that's acting funny.
J.R.
09-23-2006, 09:16 AM #6
- Jul 2005
- OHIO Go Buckeyes!
That would be the SCV (Speed Controlled Volume) also known by another name but it slips my mind at the moment.
If the radio just used an analog volume pot it would be an easy DIY fix. Since it's a digital encoder it's not as easy to fix. It may be the actual volume control or it could be the logic circuitry that goes along with it that has gone bad.
09-23-2006, 11:55 AM #7
- Aug 2006
- Folsom,CA
Black- 2002 Trans am WS6
09-25-2006, 03:53 PM #8
there might be moisture inside the HU, if you are comfortable taking the unit apart and spraying down the HU with a good contact cleaner near the controls it may fix your problem while spinning the nob both places
09-27-2006, 05:08 PM #9
09-29-2006, 06:23 PM #10
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
Mine too, son of a #@^%$@!!!!
09-30-2006, 05:46 PM #11
- Mar 2006
- Ann Arbor
Black- 2002 WS6
Monsoon volume prob
Sounds like alot of people have this problem, lucky for me I purchased a extended 5 year warranty, instead of the standard 3 year warranty, so I will be taking it in to the dealer for a free-fix.
J,.R
09-30-2006, 06:23 PM #12
Mine too!
Its only annoying when some bitch next to me touches my dial and tries to turn the sound down. Boy does that backfire on them!
For the record, mine is real bad! I just use the steering controls. Hey, my sterring control lights have gone off...how the FUCK do you replace those lights??99 T/A M6
LS6 intake, Hooker Coated Long Tubes, Y-pipe w/1 carsound cat, Hooker Catback, MTi Clear Lid, FRA w/ Holley Power Shot, ASP crank pulley, 1.8 RRs, 3.73s w/TA girdle & Eaton Differential, Granatelli SFCs, Pro 5.0 Shifter, LS6 Clutch, Diablo, TByrnes Maf Ends (in winter), All the Free Mods
09-30-2006, 07:10 PM #13
09-30-2006, 08:27 PM #14
- Feb 2006
- Galveston, TX
Search, there is a great how-to thread, probably in the stereo section archive. Worked for me.
10-01-2006, 02:15 PM #15
The system in my '95 actually does the same thing you people are speaking of, at random times. Also it refuses to play CD's with both sides of the speakers, it will only play CD's with one side (right side speakers) and it will play the radio with both.
The solution? Buy a new system, lol. Mine is old as hell so I guess this shit is to be expected.
10-01-2006, 06:30 PM #16
- MIAMI, FLORIDA
RED- 2001 PONTIAC TA RAM AIR
my 2001 ws6 also has the same problem. i just lower or increae the volume from the steering wheel instead of the knob.
10-01-2006, 10:14 PM #17
monsoon
does it do the same when you use the steering wheel controls also. If not the volume knob is a variable resistor. Once it's turned if it has anytype of contamination like dust it will do that. take it out and get a can of compressed air, do not blow in it because the moisture will come out of your mouth. so get the can and blow into it. that should help. if not take off your volume know and try to see if there is some dirt stuck in it.
10-04-2006, 07:23 AM #18
- Sep 2006
- reading, pa
Sebring Silver- 1998 Z28
I had the same problem w/ my wife's stereo in her grand am. I removed the potentiometer and measured the resistance and it was fine at one spot, but as soon as you turned it down it went to zero. I replaced it w/ a new knob out of a donor head unit and that fixed it. Definitely clean it out, but if that doesn't work you may have to replace the knob or just use the steering wheel controls from now on.
01 Monsoon Volume knob
By ls1wallen in forum Parts Wanted / TradeReplies: 1Last Post: 02-18-2010, 02:50 PM -
Help: C5 Volume Problem
By frankx0r in forum Stereo and ElectronicsReplies: 0Last Post: 06-07-2009, 04:27 AM -
Volume knob on Monsoon retarded
By mavrikZ in forum Stereo and ElectronicsReplies: 15Last Post: 06-07-2006, 12:15 PM -
Where can I buy a new volume control for stock Monsoon?
By DarthD in forum Stereo and ElectronicsReplies: 3Last Post: 12-23-2005, 03:47 PM -
Having an Odd Monsoon Problem. HELP!
By Tobynine9 in forum Stereo and ElectronicsReplies: 9Last Post: 11-30-2005, 04:03 AM
