Results 1 to 16 of 16
Thread: Volume knob on Monsoon retarded
04-28-2006, 07:59 AM #1
Something is wrong with my volume knob. It just seems like it only half way works. I turn and turn and the volume doesnt change. Then if I barely move it, it jumps up full blast. My steering wheel control works good though( God bless TA's!
) Any recommendations?
04-28-2006, 08:12 AM #2
Mine does the same thing but randomly - must be in the early stages of I need to be replaced by an aftermarket unit.
04-29-2006, 09:07 AM #3
Thats just a pontiac thing. My girlfriends grandammit did it as with about half the pontiac I've ever tried to turn down the stereo.
05-01-2006, 07:18 AM #4
Weird. Ok, thanks. Guess it still sucks, but its better to know you are not alone!
05-05-2006, 05:52 AM #5
Try to pull the knob out a little bit as u turn it, i have found that to work well.
05-06-2006, 01:34 AM #6
Lol mine does somthing completely different. When I try to turn the vol down it'll go up a few notches then go down. So whenever I have a passenger trying to answer their phone, and I try to be courteous and turn down the radio I look like an ass.
05-25-2006, 08:41 PM #7
- May 2006
So strange. My '99 T/A does the very same thing if I try to adjust the volume from the head unit. I just use the volume buttons on the steering wheel, instead. No problems there.
05-26-2006, 03:45 AM #8
It's seriously gotta be a Pontiac thing!
!! Every Pontiac I have ever owned and I've quite a few, the radio volume knob has always sucked. My 2002 Trans Am did the same exact thing so I just changed the radio... But like ya said, steering wheel controls have no problem.
go figure.
05-26-2006, 05:47 AM #9
Mine acts funny, too. If you turn it alot, it does fine. If you're trying to do minor adjustments, though is when it acts strange. You might turn it down a notch and have the volume actually go up, or vice versa.
05-26-2006, 06:00 AM #10
Originally Posted by MarkuzLS1
How weird?
05-26-2006, 08:59 AM #11
- May 2006
Originally Posted by mavrikZ
05-27-2006, 03:58 AM #12
you can try shimming the knob itself to keep it "pulled out" at all times. I don't know, it may work, it may not.
I guess all you would need is a set to washer slightly behind the button itself.
06-07-2006, 05:57 AM #13
Its Hard To Keep It Shimmed In The "pulled Out" Position. I Just Keep Pulling The Knob Out. Works For Almost Everyone Else From What I See.
06-07-2006, 11:48 AM #14
- Oct 2005
- Austin, Tx
Black/Black- 2000 Trans Am WS6 A4
mine does the thing where it started INCREASING the volume by about 15% when I try to turn it down... only when it's already pretty loud...
probably need to clean the contacts on the knob... but instead, I'm just gonna get the DEH-P980BT
06-07-2006, 12:08 PM #15
Originally Posted by ScrapMaker
NM. Google bestowed the knowledge upon me.
06-07-2006, 12:15 PM #16
- Oct 2005
- Austin, Tx
it's basically sex, compacted inside a single-din casing
Question: Radio Volume Knob
By Ant71130 in forum Stereo and ElectronicsReplies: 2Last Post: 06-16-2012, 10:27 AM -
volume knob
By ls1wallen in forum Stereo and ElectronicsReplies: 5Last Post: 02-23-2010, 02:15 PM -
01 Monsoon Volume knob
By ls1wallen in forum Parts Wanted / TradeReplies: 1Last Post: 02-18-2010, 02:50 PM -
Monsoon Volume problem
By jroc in forum Stereo and ElectronicsReplies: 17Last Post: 10-04-2006, 07:23 AM -
Where can I buy a new volume control for stock Monsoon?
By DarthD in forum Stereo and ElectronicsReplies: 3Last Post: 12-23-2005, 03:47 PM
