09-19-2006, 06:37 PM #1
- Sep 2006
- Chicago
Black- 2000 Grand Prix GTP
abs/ tcs lights always on 2000 GTP
I was wondering if anyone else has this problem. On my 2000 Pontiac Grand Prix GTP, the tcs light and the abs light are both illuminated constantly. I am still able to operate the vehicle normally, but it is annoying. My friend has a 2001 GTP with the same issue. Is this a widespread problem? Is GM aware or doing anything about it?
I sincerely appreciate any insight....
Thanks
09-19-2006, 06:52 PM #2
i found on my camaro that my ground wire was loose on the radiator support when those lights were on,also my wipers did not work
09-20-2006, 07:35 AM #3
Unplug the two front wheel speed sensors and reconnect them, it
is usually a bad connection or possibly a bad one if that does not
fix the problem......
09-20-2006, 03:53 PM #4
- Sep 2006
- Chicago
Thanks
I will try this fix. I appreciate the reply.
09-20-2006, 04:57 PM #5
- Jan 2006
- Shepherd, Michigan
its a common problem in the n-bodies..its a bad wheel hub assembly/water getting into the hub assembly... i think...so it causes the abs and tcs to constinatly switch on and off..i'm talking like in rapid succsesion...you need to have it checked as soon as possible..becuase when it rains heavy or snows ..abs and tcs will be turned completely off. go to grandamgt.com thats were it should be at..its been forever since i read it. hope it helps
Help: Moisture in reverse lights 2000 T/A
By fbodyNATION in forum Firebird / WS6Replies: 6Last Post: 09-20-2011, 12:07 AM -
Help: 2000 Grand Prix brake lights
By rschap1 in forum General HelpReplies: 33Last Post: 09-07-2010, 04:23 PM -
Question: 2000 WS-6 HID Lights
By Taurian00 in forum Firebird / WS6Replies: 13Last Post: 03-12-2010, 03:40 AM -
Help: 2000 Corvette head lights
By Nastyfoot in forum General HelpReplies: 0Last Post: 05-20-2009, 07:13 AM -
Help: 2000 Trans am lights flicker!
By juvie909 in forum Firebird / WS6Replies: 18Last Post: 05-08-2009, 07:42 PM
