    Jun 2006
    Shelly, Minnesota
    spice red metallic
    2006 GTO
    Spark plug swap on GTO
    I was wondering what plugs you guys have switched to. I see many are running NGK TR-55 and some have mentioned NGK TR-6 or 7. Is there any real benefit to switching out or are the stock ones fine on a GTO with a Borla and possibly a cold air kit or Amsoil drop in filter? The only other mod I might be planning for now is a Predator tune.
    Retired Outlaw Sum Bitch
    NAh TR55R's are just fine for your application....Go one range cooler with a head/cam or power adder car to the TR6's.....
    txcosmos
    Guest
    So I should change them to the TR6's?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Autolites
    I'm running the Autolite Racing plugs which use a cut-back ground and a solid copper core.
    AR-94 or AR-93's depending on how much bottle......You can get AR-95's which would be about a half of heat range cooler than stock.
    Quote Originally Posted by txcosmos View Post
    Yes...now that you have the Patriot heads setup I would go TR6's....
    txcosmos
    Guest
    OH-Tay...
  1. NGK spark plug
    By Cutlass in forum External Engine
    Last Post: 03-13-2010, 07:20 AM
  2. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  3. spark plug w/ oil all over it...HELP!!!
    By L3THAL_Z28 in forum Internal Engine
    Last Post: 10-25-2007, 11:38 AM
  4. Spark plug wire and plug!
    By RYDER661 in forum General Help
    Last Post: 03-13-2006, 09:01 PM
