    Junior Member 99PTA's Avatar
    Feb 2006
    Iowa
    Medium blue metallic
    99 Trans Am
    Metal in oil HELP
    Was changing oil in my TA when I noticed three needle bearings stuck on the magnet on the drain plug. I'm thinking it has to do with my rockers but need some more info on what it is and what it will cost to fix. Car runs and sounds great.
    Senior Member
    Jacksonville, FL
    Yeah, it's from the rockers. Remember seeing some pics someone posted on another board and mentioning a TSB on it several months ago, they're really small. If I remember correctly GM says you need to replace all the rockers and change the oil again after some miles. If you need it I'll search around for it tomorrow for you. Sorry...maybe you can identify which one it is, but I'd replace them all.
    Senior Member
    Jacksonville, FL
    Before signing off I did a quick site search here for "needle bearings" and found this: www.ls1.com/forums/showthread.php?t=24114
    Feb 2006
    Iowa
    99 Trans Am
    Yep it's the rockers. Car only has 42k. I found a replacement on gmpartsdirect and it's only 23 bucks a rocker but I think it's time to upgrade to rollers. thanx
  1. Ron Fournier: Metal Fabricator - Metal Man
    Last Post: 03-03-2011, 12:47 PM
  2. NOS sheet metal
    By nuttyprofessor in forum Classic Muscle
    Last Post: 11-21-2010, 02:59 PM
  3. Metal music \nn/
    By Pony_Eater in forum Almost Anything Goes
    Last Post: 11-13-2010, 10:14 AM
  4. help--Metal in Metal chatter- need homemade gasket
    By jrc1122 in forum Manual Transmission
    Last Post: 06-03-2008, 03:30 AM
  5. Istalled new pushrods, now new metal on metal noise
    By brokenls1 in forum Internal Engine
    Last Post: 02-02-2006, 03:29 PM
