Results 1 to 13 of 13
    San Diego
    1999 Camaro Z28 (SS kit)
    Is it my clutch,petal assembly,or both that is sticking under WOT on NX wet 150 shot?
    I have a ZO6 clutch now on my '99 Camaro 6spd with 4.10 gears, but still, from a dead stop at WOT, my clutch sticks after the NX wet 150 kicks on and shifting to the next gear and stomping on the throttle again just leaves the clutch partially stuck in forever....burning it up and not allowing the full power to the ground.
    Is it my clutch?
    Is it my petal assembly?
    Is it my 4.10 gears?
    Is it all the above?
    Anything I can do besides comments telling me to change clutches?
    If I do a roll out it is fine....just when I use it from a dead stop is when I have this prob? I remember reading some sort of GM recall or problem with petal assemblies as well?
    Thanks,
    Rich
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    could also be the main rear seal leaking on the clutch.
    Eugenio_SS
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Its not your gears, I can tell you that much.
    Is the whole pedal not returning to its top position, or is it the clutch itself that won't engage?? Either way it sounds like its a hydraulic problem, if the clutch was slipping due to a seal leak it would still engage all the way, but it would slip once engaged.
    If the clutch won't even engage all the way, first thing I'd check is hydraulics.
    Senior Member Blown Interceptor's Avatar
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    Quote Originally Posted by Wesman View Post
    I gave him my hyd setup from my 2000 Z-28, that I upgraded to the new hyd. clutch system. Could the clutch need to be bled?
    Jason
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Blown Interceptor View Post
    Definitely sounds like a hydraulic system bleeding issue. If theres air in the lines it will make the clutch/pedal react slowly or act strangely.
    Bleed the system first, and then diagnose it from there.
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    Thanks for the info!
    San Diego
    I guess I am really running:
    Z06 clutch/flywheel + drill mod + upgraded hydro's
    To desc how it feels...when I nail it and the juice kicks in, it feels like the petal needs to come out another few inches for the clutch to be released all the way...of course, once I shift to 2nd, it was burning the clutch in first, so it cont's to burn it in second. It is really annoying. This is how my old clutch was also. You could smell the clutch burning at the track too since it was not coming all the way out.
    How do I bleed my system the right way? Any good write ups? Is it easy?
    Rich
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    It's just like bleeding the brakes, if I remember correctly...there should be a nipple and top of the tranny, right?
    San Diego
    Okay, maybe you guys think I am an idiot for doing this, but my local GM dealer said to bring it in at 8:15 tomorrow morning and for $89 they will bleed my hydraulics and check for any leaks.
    At least I can rule these out if they bleed it correctly, which they said they will.
    Think $89 is a crazy amount to pay? Think they will do it right?
    Rich
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    I would do it. 89.00 bucks to do that by GM. Not too bad.
    San Diego
    Yah, unless Mr. goodwrench fucks the car up trying to get it on a lift, etc...bow out my fenders, etc...sometimes nightmares come true buddy!
    Rich
    Aug 2006
    california
    allllllllll black
    2002 35th z28
    GM: DEALERS will take it to ya if they can,so that price is good i say do it. but expect them to tell you it wont bleed right or something and say you need all new shit.
    Junior Member extanker's Avatar
    Jun 2006
    trenton nj
    07 z06
    sticking clutchs are issue with new vettes and no one has the big cure. ya did the drillmod you say. were was the restrictor ? vettes were in the line at slave while birds are in line at master ? what color is fluid any gunk in master are lines too close to exhaust. if driving normal were does clutch first engage eg:high pedal release or off the floor
  1. Clutch pedal sticking 98 TA
    By nochey in forum Firebird / WS6
    Last Post: 04-24-2012, 11:14 AM
  2. Help: Clutch petal
    By Bigck4 in forum Drivetrain
    Last Post: 01-26-2009, 10:58 AM
  3. Clutch pedal sticking
    By DrMilhouse in forum General Help
    Last Post: 02-10-2008, 04:47 AM
  4. Clutch Sticking to the Floor??
    By Roastem in forum Manual Transmission
    Last Post: 06-10-2006, 12:25 PM
  5. For those with clutch sticking problems...
    By swimster144 in forum Manual Transmission
    Last Post: 03-16-2006, 10:19 PM
