Results 1 to 3 of 3
Thread: Clutch Sticking to the Floor??
06-09-2006, 06:15 AM #1Evr sena bdgr killa snak?
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
Sometimes when I crank the car up in the morning and push the clutch in, it sticks to the floor. It just starting doing it recently. I have to reach down, and pull it up (it feels like its stuck, WTF?), then pump it a couple times, and it works fine the rest of the day. What is up with that? I think it has the factory '99 master and slave, should I upgrade? If so, to what kit? I heard the '02 master and slave were good, and I know there are some aftermarket setups out there too. Any advice would be appreciated!!
Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
BMR track suspension, full exhaust, the works...
412whp/394wtq 1/4 mile slip coming soon!
Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
06-10-2006, 12:12 PM #2Junior Member
- May 2006
- englewood,fl
silver- 00sscamaro
had same problem with mcleod master cyl.removed spring on clutch pedal.fixed my problem.then seal went bad in master cyl at track 5000 rpm launch welded clutch to flywheel,spec stage 3.replaced clutch and seal no problems now. spring still off.
06-10-2006, 12:25 PM #3Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Upgrade to 01+ master
Clutch pedal sticking 98 TA
By nochey in forum Firebird / WS6Replies: 5Last Post: 04-24-2012, 11:14 AM -
Clutch pedal sticking to the floor.
By jrummi in forum Manual TransmissionReplies: 30Last Post: 04-05-2010, 01:18 AM -
Help, Clutch Pedal Sticking to floor at High RPM's
By transam207 in forum General HelpReplies: 16Last Post: 03-30-2009, 05:31 PM -
By DrMilhouse in forum General HelpReplies: 3Last Post: 02-10-2008, 04:47 AM -
For those with clutch sticking problems...
By swimster144 in forum Manual TransmissionReplies: 3Last Post: 03-16-2006, 10:19 PM
