Results 1 to 17 of 17
    WS6 Lover transam207's Avatar
    Dec 2008
    Kalamazoo, Michigan
    2000 Pontiac Trans Am WS6
    Exclamation Help, Clutch Pedal Sticking to floor at High RPM's
    My clutch pedal sticks to the floor at high RPM's. But when I drive normal it doesn't have any problems. Can someone help me out and let me know what it sounds like the problem is. When I race or full throttle my car the pedal sticks to the floor and is almost impossible to shift into the other gears, but once it sticks to the floor I can pull it up with my foot and pump it up a little and then it will work just fine again. I re-bleed the hydraulic system, and drilled out my hydraulic line, but dont know what else to do. Not this last winter but the winter before, I replaced the master, and slave cylinders, and replaced the clutch. But can someone please help me out. Thanks!
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    should be all you need to know
    http://www.ls1.com/forums/showthread.php?t=55824
    Dec 2008
    Kalamazoo, Michigan
    Quote Originally Posted by Dr.Crash View Post
    If I already replaced the parts about a year and a half ago, can the parts be bad again? They can go that dang fast. I did everything on that thread except replaced the master and the slave, but like I said I replaced them a little over a year ago. But maybe they need replacement again! Any other suggestions???
    Dec 2008
    Kalamazoo, Michigan
    Thanks but i did do everything up to replacing the master/slave cylinders. Do you think I will have to replace them again If I already replaced them a little over a year ago? Any other suggestions on what I could try???
    Feb 2006
    Stock
    2002 Camaro
    i would try bleeding it again. if you just replaced everything, then it must just need to be bled. maybe there is something blocking the line. did you get all of the shavings out when you did the drill mod?
    Dec 2008
    Kalamazoo, Michigan
    I tried to do the drill mod once it was all removed, but once I got it out and started drilling there was no restriction what so ever, so I am thinking that the previous owner already did the drill mod on the line. But I will try re-bleeding it again.
    Slowass SUX!!
    Nov 2008
    Cincinnati
    09 Sierra Denali AWD
    2001 T/A WS6 NBM
    Dec 2008
    Kalamazoo, Michigan
    Thanks but I believe I fixed the problem. It was the master cylinder. But I just now have to re-bleed the system for the 4th time in 3 days.
    Feb 2006
    Stock
    2002 Camaro
    what was wrong with it?
    Dec 2008
    Kalamazoo, Michigan
    I have no idea. It must of been just a bad part. My Hydraulic/Brake Fluid was black as hell, and I think it ruined my Master cylinder. I did all the steps up to the Master Cylinder and nothing fixed it. Now I can go high RPM's and shift into the other gears, but I still have a little problem with the 3rd gear, but there might still be a little bit of air in the line still.
    San Antonio
    Silver & Black
    99 Camaro SS
    Mine was the slave cylinder. And it is common. My problem was exactly like yours at the start and got worse. What makes this difficult is all of these other things can help. Flushing and new fluid improves fluid density and helps compensate for a slave or master cylinder that is bleeding through. Then if both are failing changing one helps.
    Dec 2008
    Kalamazoo, Michigan
    Quote Originally Posted by BowTied View Post
    Huh, mine could be the slave unit (thats why it still sticks a little in 3rd), but it is one hell of a time to get to the bleeder valve on these cars. Did you drill through your floorboard to get to the bleeder valve?
    San Antonio
    Silver & Black
    99 Camaro SS
    No. But I was changing my clutch, flywheel, and drive shaft. So we had the car up pretty good.
    Dec 2008
    Kalamazoo, Michigan
    Oh...ok maybe I'll end up having to do that too. If this 3rd gear problem is the slave cylinder then I'll be doing the same thing you did. Cant Wait!!
    Feb 2006
    Stock
    2002 Camaro
    Quote Originally Posted by transam207 View Post
    they make a speed bleeder so you can blled your slave from the engine bay. its not to expensive and i recomend it to anyone i can. ask mark from KYSpeed, he has the hook up on these!!!! Good luck
    San Antonio
    Silver & Black
    99 Camaro SS
    If they are rather inexpensive it would be a good plan. Even up good it takes w a while to bleed, probably 15 minute or so. And depending on your set up it takes a while to get the car up...I had it up like 2 feet.
    Dec 2008
    Kalamazoo, Michigan
    Thanks guys for all the help. I appreciate it all.
  1. Clutch pedal sticking 98 TA
    By nochey in forum Firebird / WS6
    Last Post: 04-24-2012, 11:14 AM
  2. Sticking clutch pedal write-up
    By JonB in forum Manual Transmission
    Last Post: 09-04-2011, 02:03 PM
  3. Clutch pedal sticking to the floor.
    By jrummi in forum Manual Transmission
    Last Post: 04-05-2010, 01:18 AM
  4. Clutch pedal sticking
    By DrMilhouse in forum General Help
    Last Post: 02-10-2008, 04:47 AM
  5. Clutch Sticking to the Floor??
    By Roastem in forum Manual Transmission
    Last Post: 06-10-2006, 12:25 PM
