Thread: oil pressure switch.
09-13-2006, 03:22 AM #1Junior Member
- Sep 2006
- australia
hyper yellow- 2002 vu ss holden 290 rwk
just wondering if someone can tell me roughly where the oil pressure sender switch is situated and are they much of a hassle to replace?.
09-13-2006, 04:14 AM #2Junior Member
- Sep 2006
- Hampshire, UK
Red- 2000 Trans-Am
Right at the very back of the intake manifold.
Standing at the front of the car, reach to the ack of the manifold and to the right a bit, there is a pipe going from the back of the manifold to the vaccumm of the brakes, its between that pipe and the manifold.
Really to replace it you will find its best to remove the intake manifold, only 10bolts, plus unplugging the injectors and fuel rail. Perhaps you can change it without removing the inake manifold but if you can it will be extremly differcult in my opinion, would e quicker to take the maifold off.
I broke my sender when changing my valley cover screws, the rathchet swang round and knocked the sender. Its easy to brake the sender when removing the intake manifold, the same for putting it back. You may want to search for posts on removing the intake manifold. I can get it off and back on again in 30mins.
09-13-2006, 06:42 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
Yeah, behind the intake on the drivers side. GM makes a socket/tool for it to make it easier to replace with the intake on.
09-13-2006, 09:49 PM #4Junior Member
- Sep 2006
- australia
ok
thanks for the info guys,i think ill have a crack at it with the manifold on,hopfully the the gods will be on my side,
cheers Darran
A/C Pressure Switch Re[lacement Help
By 9T8WS6 in forum General HelpReplies: 1Last Post: 11-16-2016, 05:29 PM -
Help: p1810 Trans Pressure Switch code after shift kit install?
By ari1843 in forum Automatic TransmissionReplies: 4Last Post: 06-26-2015, 10:39 AM -
wire from stop lamp switch to turn/hazard switch?
By swisscheese in forum Stereo and ElectronicsReplies: 1Last Post: 08-12-2008, 12:22 AM -
FJO and/or Fuel Pressure Safety Switch
By captainwizbang in forum NitrousReplies: 2Last Post: 09-05-2007, 12:21 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 04:59 PM
