    pyro71985
    Guest
    ~LOW budget turbo build~
    Has anyone here done a LOW budget turbo set up? If so how much did it cost?
    If not how much do you think I could build one for, buying used, off of ebay, classifieds, doing most the work myself. etc etc etc
    I went to Playboy Mansion FantaZGuy28's Avatar
    Bakersfield/Long Beach Ca
    YJ
    04 GTO M6
    If you want to go supercharger...low budget I have a Powerdyne that I rebuilt and have not put on my car(since the rebuild) and it made 383RWHP and 399RWTQ with just the basic boltons(lid, Ypipe and Loudmouth).
    pyro71985
    Guest
    how much?
    YJ
    04 GTO M6
    You have a PM.
    Member ericwilloughby's Avatar
    Louisville KY
    Yellow
    2005 GTO
    I have also been toying with the DIY turbo idea. What I have so far is:
    2x TD05H turbos with 16G comp wheels ($760 Shipped for both) 380Hp each
    1x 24" x 12" x 4" Intercooler with 3" inlet and outlet ($200 Shipped)
    2x Set of oil feed lines to turbo ($100)
    2x Set of oil return lines from turbo ($90)
    2x Manifold to turbo Custom Pipes ($200)
    2x Custom Downpipes ($300)
    2x Airfilters ($80)
    8x Injector ($500)
    1x Fuel Pump ($150)
    1x HPTuners ($499)
    1x HKS Blow off valve ($105 shipped)
    I am looking at intakehoses.com for the hoses from turbo -> IC -> Inlet.
    Could be as much as $300.
    Subtotal: $3330.00
    I am looking at placing the turbos where the battery and airbox used to be (similar to LPE kit)
    Those turbos are cheap. What is a TD05h?
    Intercooler cheap.
    Pipes cheap.
    Oil lines NOT. Wow. I can get 3,000 PSI hoses made for my International tracked loader at NAPA for $100.
    Are the prices for the pipes confirmed?
    Air filters $80. That sucks I guess there isn't another option?????
    I want to START out with a kit like yours minus the injectors, fuel pump, HP Tuners, BOV. Save $1105 Just for now. & add E85 injection as a first upgrade step $200 I think.
    That should put the basic hardware at about $2200 for a twin kit.
    Going the single route would save a lot more. Why aren't you looking at that? Price of the single turbo too high?
    If you put the turbos on top will there be room to run an up and down pipe beside the factory exhaust manifold?
  1. LS3 budget build
    By pupi305 in forum LS2/LS3/LS4/LSx
    Last Post: 04-23-2013, 09:30 AM
  2. Budget 5.3 build
    By shmokinjoe in forum Internal Engine
    Last Post: 12-09-2009, 06:53 PM
  3. Question: Budget Build
    By David Q in forum Corvette
    Last Post: 11-19-2009, 03:13 PM
  4. Budget build.
    By state69champ in forum LT1
    Last Post: 04-10-2008, 08:57 PM
  5. HELP! Budget Build Up
    By juiceboxx in forum General Help
    Last Post: 03-19-2006, 09:18 AM
