Results 1 to 18 of 18
    From 2JZ to V8 juiceboxx's Avatar
    SoCal
    HELP! Budget Build Up
    Hi. I am about to purchase a 98-02 camaro/firebird. I am leaning toward a 01 Z28 Camaro M6. I am going to have about 4k to put into mods, etc.
    What do you guys think I should get? (Imagine the car I buy is 100% stock)
    Thanks Everyone!
    SoCal
    Even though it is a small budget, I do not want boot leg of half-assed products. If that plays into the picture of knowing what to get.
    Looking to buy a 98-02 Camaro/Trans Am!
    PM me if you have one for sale!
    SoCal
    What do y'all think? Help me out!
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    What do you want the car to do? Street/Strip? Street/AutoX? Street/Road Course? The order of the mods will be determined by what you want to do with the car and the areas of focus. If you do installs yourself you can strech the money a bit.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    Id do suspension, headers, ls6 intake, high flow cats, drag radials, and loudmouth exhaust.
    Get you some Sub frame connectors, Spohn race rear sway bar, spohn adjustable torque arm, and if you can afford it, tubular k-member and A-arms.
    Thats if your looking for just a one shot deal that you will get the most out of. If you are considering this just a steping stone of mods to come id start with a 12 bolt and do the whole suspension.
    SoCal
    Im looking to keep it street legal and use as a daily driver.
    Newport News Va
    1998 WS6 M6
    Street leagal is a very vauge term. Daily driver is too. Some states consider a car with just a modified exhaust to be illegal. Some people think aftermarket exausts are to loud or... some cams are to agressive, while others are okay. Some people can do without their A/C's and others cant part with them. You need to be more specific.
    SoCal
    Allright. I need a VERY reliable car. I need one that can get me from school to school and around the state. I live in california, so the dB has to be under 98 dB. I have a smog hook up, so that doesnt matter. I will drive this car roughly 20 miles a day, but I want it to be faster than the average car out there.
    SoCal
    Quote Originally Posted by Capster78
    Sorry, what is a 12 bolt?
    Newport News Va
    1998 WS6 M6
    its a stronger rear end than the stock one.
    SoCal
    How much are those? What brands are the better ones?
    SoCal
    How are the SLP loudmouth compared to flowmasters and borla exhausts?
    What intake should I buy?
    What should be bought third?
    illinois
    torch red
    99 c5
    with four grand i would do the following mods 100 hp nitrous kit 1,000 installed
    3.73 ring and pinion 600.00 installed!!
    computer tuning 500.00 flp performance
    quick time cutouts 500.00 installed
    cold air kit 200.oo install yourself
    jegs biggest that will fit on car drag radials 500.00 installed
    cut your shifter in half and reweld it for a short throw FREEBIE
    save the other 400 for a solobaric in the back
    if your car does not do 11.9's to 12.3's you can punch me in the face
    i dont want to hear anyone tell me that this car wont be a fast mother f'er and totally streetable... damn does this little nitrous burning c5 owner know it all or what...
    SoCal
    Quote Originally Posted by c5andtyphoon
    I want to stay away from the spray. You wouldnt install an exhaust?
    Newport News Va
    1998 WS6 M6
    bottles are for babies. Power on tap when you can afford to fill the bottle. Bad enough you have to pay out the ass for gas. Now you have to fill a bottle.. naaaa..
    SoCal
    Well said. What octane do people use with SS Camaros?
    quicky06
    Guest
    93 octane. anything else and it will be knockin on your door
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    If you are getting an '01, you won't need an intake. You'll get the LS6 intake on any 01-02 car that is worth 7-10 rwhp over the previouse years LS1 intake.
    Cutouts are the easiest way to open up your exhaust for performance, but not have an obnoxious sound the rest of the time. Many people prefer a cat back of some sort to get a better sound when driving (stock is pretty quiet).
    I'd say do a lid and high flow filter, headers and and off road Y if you really have a smog hookup. You may decide you like the way it sounds with the headers and no cats and save your money on the cat back. Once you've got the supporting mods, heads and cam will make a huge difference (a package from PATRIOT PERFORMANCE is probably the best bang for the buck). After all that, you'll make the most of your mods with a good dyno tune. Then you'll want some subframe connectors and rear lower control arms to put it to the ground, along with some drag radials.
    Engine mods $2250 - $2750 depending on what headers you choose.
    Tuning $300 - $500 depending on tuner
    Chassis & Suspension $300 - 400
    Drag Radials $300
    $3450 - $3950
    Hammer - hammertime.us
    2001 Light Pewter Metallic Camaro SS, 6 speed
    K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
  1. LS3 budget build
    By pupi305 in forum LS2/LS3/LS4/LSx
    Last Post: 04-23-2013, 09:30 AM
  2. Budget 5.3 build
    By shmokinjoe in forum Internal Engine
    Last Post: 12-09-2009, 06:53 PM
  3. Question: Budget Build
    By David Q in forum Corvette
    Last Post: 11-19-2009, 03:13 PM
  4. Budget build.
    By state69champ in forum LT1
    Last Post: 04-10-2008, 08:57 PM
  5. ~LOW budget turbo build~
    By pyro71985 in forum Forced Induction
    Last Post: 10-07-2006, 10:58 PM
