Thread: gears or stall
08-28-2006, 01:25 PM #1Junior Member
- Apr 2006
- canada
white- 1997 trans am
gears or stall
Just wondering which way to go? have stock 3:23 gears with auto trans. i put a set of 10X26-16 slicks on and i now have a problem with keeping the vrevs up when it shifts to second because there is no wheel spin when it shifts. i have 315 35 17 street tires and run around 13.6 on my g timer, with a fair bit of wheel spin, but with the slicks i can't crack the 14 second mark although my 60 ft times are better because i'm hooking up. car is putting out 331 rwhp and has ashift kit, it is programmed to shift at 6500 rpm. wondering if gears are the way to go or will stall converter solve my 1-2 shift. thanks in advance for any advice. 97 ta 383 stroker.
08-28-2006, 01:33 PM #2Member
- Aug 2006
- NC
mystic- 95 LS, yes it says LS
Go with a stall. At least 3000 lock-up. I'm not a hard racer but its my.02
09-03-2006, 08:06 AM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Stall before gears
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
09-03-2006, 08:39 AM #4Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Stall and cooler. 3400 stall and BM cooler.
09-04-2006, 02:45 PM #5Grand Imperial Wizard
Here is a simple formula to determine if you need lower or higher gear ratio than what you have...
ET x MPH = 1335
If your answer is more than 1335,you need more gear.
If your answer is less than 1335,you need less gear.
09-04-2006, 04:19 PM #6Member
- Sep 2005
- Pueblo, Colorado
Black- 1998 Pontiac Trans Am
stall
09-09-2006, 12:50 PM #7Junior Member
- Apr 2006
- canada
gears or stall
thaks for the advice guys. went to the track for the first time last saturday, best run 13.12 @ 106mph, 1.96 60 ft.
Best Stall/Gears for MS3?
By IT_SS in forum Internal EngineReplies: 19Last Post: 04-04-2010, 06:45 PM -
Have gears want to add a stall
By dred in forum Automatic TransmissionReplies: 16Last Post: 03-03-2010, 02:33 AM -
stall or gears
By LT1 > LS1 in forum DrivetrainReplies: 16Last Post: 08-10-2008, 08:23 AM -
gears and stall
By rjb41384 in forum Firebird / WS6Replies: 2Last Post: 06-14-2006, 07:09 AM -
Stall and Gears
By SSzoe in forum Automatic TransmissionReplies: 6Last Post: 10-08-2005, 07:17 AM
