Results 1 to 17 of 17
    Jun 2006
    b.c.
    2001 camaro ss
    Have gears want to add a stall
    Installed 3.73's on my 01 SS A4 would adding a stall too make a big difference on my 1/4 mile times? Also how about a 3400? No other mods.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Yes and most people will say YES
    Yes a stall will put the motor in the power so to speak when you leave the line. if you race alot most people will probably tell you to go higher on the stall but it is a personal choice so talk to people around here and at your track to see were you want to be.
    Omaha, NE
    2000 Z28 Camaro
    3600 for a daily driver or weekend warrior. get a 4000 if you are kinda ballsy like me. i hope you have tires, you will need a drag radial or better to get any kind of traction.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by allbaugh_04 View Post
    +1 I'm running a 3,800 and it drives almost stock till you get on it. I'd say 3,500-4,000 will make you happy, plus don't forget to get a tune after you put the stall in
    Member TA98's Avatar
    Mar 2009
    Maryland
    Is your car relativly stock right now? Cuz im putting 3.73's in my car whenever i get around to doing it and i was wondering what kind of times you have
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Like I always say. Stall before gears. And it should be the first mod on an A4.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Aug 2009
    Illinois
    Quote Originally Posted by dred View Post
    I made that mistake, I tried a Yank 3200 stall and the car slowed down.
    Aug 2009
    Illinois
    Quote Originally Posted by Autoslick View Post
    Just got off the phone with a buddy that kicks my butt. He uses an 11 inch 2500 stall from Midwest Converters and said he cut a half a second off the 1/4 mile. Does any one have their phone #?. I think I'll try one and let you guys know how it does.
    Aug 1999
    No Where
    That doesn't make any sense. MPH maybe, but it will cut almost a second in the 1/4
    Omaha, NE
    2000 Z28 Camaro
    he probably just spun
    mercersburg pa
    hugger orange
    2004
    I was guessing traction problems too....i went from a 3,000 to 3,800 stall and its like two different worlds........i DO have traction problems now, but that can be solved with a set of sticky tires
    houston tx
    06 chevy silverado
    I have a 2500 stall on 2006 silverado swap from 4.3 v6 to 6.0 v8 what gear is good for a daily driver?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    3.23 to a 3.73 take your pick. 3.23 for lots of high way ocasonal trailer around town, 3.42 for a compromise between 3.23 and 3.73 and trailer on the highway from time to time, 3.73 for towing on the highway most of the time, and 4.11's or more if it is going to be off road or in the mud most of the time. These are the fuel economy and use reasons to go with them.
    What are you using the truck for? that has alot to do with what gear you want. By the way you may want to post this question in the rear end section under a new thread because this one is old and you may not get people looking because the title is about something else.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by JaycenK View Post
    maybe even higher than 4.11's depending on tire size.....if running bigger tires, lots of playing in the woods and mud, and little or no highway travel I'd even look at 4.30s or 4.56s
    what size tires are you running?
    houston tx
    06 chevy silverado
    The truck is mainly used for sales house to house driving, I have 295 nitro trail grappler with all that meat they run to 31.5 I have a lq9 with headers, Texas performance. Tranny Hp tune this week , magna flow exhaust. I will be turboing in 2 months
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by kerz7500 View Post
    since your turbocharging it, i'd stick with maybe a 3.90 (it will let you get more out of your boost)
    Feb 2010
    semiferger
    semiferger
    semiferger
    Do a search, and please don't put anything more than 3.42's. If you go with 3.90's or 4.10's you basically get rid of first gear and now you can start out in 2nd gear (same as your first gear with your stock gears). So essentially you just turned a 6 speed into a 5 speed. That would be a huge waste of money.
    I've explained this before, but most people just can't think clearly when they've had years of experience with 3.42's, 3.73's, 3.90's, and 4.10 gears. The A6 is a different animal. It has a 1.53 third gear instead of the 1.00 third gear in the A4. So the A6 with the stock 2.56 rear gears is the same as an A4 with 3.92 rearend gears.
    I personally like the 2.56 gears. They act like an A4 with 3.90 gears when you run the quarter, but it acts like a manual 6 speed when you are cruising. One of the few cases where you can have your cake and eat it too.
    Good luck.
  1. Best Stall/Gears for MS3?
    By IT_SS in forum Internal Engine
    Last Post: 04-04-2010, 06:45 PM
  2. stall or gears
    By LT1 > LS1 in forum Drivetrain
    Last Post: 08-10-2008, 08:23 AM
  3. gears or stall
    By 97ta in forum Drivetrain
    Last Post: 09-09-2006, 12:50 PM
  4. gears and stall
    By rjb41384 in forum Firebird / WS6
    Last Post: 06-14-2006, 07:09 AM
  5. Stall and Gears
    By SSzoe in forum Automatic Transmission
    Last Post: 10-08-2005, 07:17 AM
