    Member mvvette97's Avatar
    leon iowa
    1997 corvette 00 WS6 TA
    problem with K&N filter fitting loose
    Anybody had this problem? I had a K&N in my WS6 and the filter was not tight in the air box. I could reach in through the holes and push up on it. I thought maybe the foam strip was gone that sticks on the underside of the lid but it is there. It is part#33-2118 so it should be the correct one. HELP!
    Member Tman's Avatar
    Woodstock, GA
    2000 WS6
    I run a Holley.. But a friend of mine has a K&N ...his came with a
    gasket. Did yours have a gasket in the box for a seal??
    leon iowa
    Quote Originally Posted by Tman View Post
    Yea it did. It shows that you put it on the lid but it is still loose. Where did you get the Holley?
    Bragg NC
    Met. Sunset Orange
    01 SS
    I had the same issue and then some so i went back too paper.
    problem solved
    J
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    That's the very reason I shitcanned that POS K & N and run a paper!
    $50 filter that lets dirt into my engine, yeah right!
    Woodstock, GA
    2000 WS6
    Quote Originally Posted by mvvette97 View Post
    Check out a few of the sponsors on the board. Many sell it.
    Member va2001ss's Avatar
    Northern Virginia
    2001 Black SS #5228
    The K&N that the LS1 takes was originally sized for a Jeep(cross reference it) that's why it is not an exact fit like paper or others.
    Marylandistan
    2001 Trans Am (sold)
    Paper ftw
  1. oil filter fitting on new oil pan
    By nath in forum LSx Retrofit and Swap
    Last Post: 01-02-2012, 04:45 PM
  2. Oil fitting-new!
    By Jarlaxle in forum General Help
    Last Post: 11-21-2009, 11:46 AM
  3. problem getting caliper loose to change pads
    By Speedy_Gonzales in forum General Help
    Last Post: 08-11-2007, 07:08 PM
  4. lid airbox filter problem (added ws6 lower box)
    By CDS98Z28 in forum General Help
    Last Post: 10-02-2006, 09:02 AM
  5. K&N air filter, loose piece of wire found WARNING
    By SV8 in forum External Engine
    Last Post: 03-03-2006, 04:48 PM
