Thread: Bottle location
    Car RamRod 98Camarod's Avatar
    Feb 2006
    Goose Creek, SC/ NWS
    Green
    1998
    Bottle location
    Where does everyone who has nitrous put their bottle? I was thinking about mounting it over the driveshaft tunnel because I have a t-top. The bottle has to be mounted on the brackets for the proper flow right? Any other suggestions?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    spare tire compartment is the more common area.
    LS1 man
    Guest
    I put mine in the sparetire compartment, Cut a 8"x16" piece of 3 1/4" particle board out and paint it flat black. That will fit perfectly in the compartment and at the right angle. Put the board in there and than put the bottle on it for a refference as to were to mount the brackets. Take the board out and mount the bottle brackets to the board using bolts, nuts and washers. Now mount the board in the compartment using a couple long drywall screws ( you can see about were to screw these through the board and through the body ) I think it is 1 at the top right and 2 at the bottom. Now for a little more security use 2 L brackets and mount the on the board close to the left hand side. Screw the bracket to the board and also to the metal body of the car. Mount the bottle to the brackets and have the valve pointing down. Looks good and fits like a glove.
    Feb 2006
    Green
    1998
    thanks for the info
    Austin, Tx & Daytona Beach, FL
    black & red
    '95 Camaro
    i'm going to put mine on the hump between the back seats with custom alum. brackets, should look pimp
    '95z m6 black w/ red stripes
    solid roller 396
    http://host41.hrwebservices.net/~wac...y_sig3temp.jpg
  1. Best bottle location and legal?
    By PUNISHERx216 in forum Nitrous
    Last Post: 03-10-2013, 09:58 AM
  2. Nitrous Bottle location
    By Corvettekid82 in forum Convertible
    Last Post: 12-18-2008, 07:00 PM
  3. bottle heater, FPSS, bottle opener, camaro door panels
    By oneBADDz in forum Parts For Sale / Trade
    Last Post: 11-04-2007, 09:37 AM
  4. Replies: 2
    Last Post: 06-03-2007, 06:46 PM
  5. Bottle Location
    By DKzar in forum Nitrous
    Last Post: 12-19-2005, 07:00 AM
