Results 1 to 20 of 23
Thread: Bottle Location
    DKzar
    Guest
    Bottle Location
    I want to install a nos system but really don't know where to mount the bottle. I frequently have my seat folded down and stuff the cargo area to the max. Other times I have a passenger in the rear, so mounting on the rear floor is out.
    Any suggestions? How about a smaller bottle tucked under where the spare tire mounts?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    That is a good spot but I would recommend an electric bottle opener if that is the case. No quick access any other way.
    Member dreaded_hope's Avatar
    Edmonton, Alberta, Canada
    97 Firebird
    Check the link in my sig, I mounted my bottle there, great spot.
    1997 Firebird 3.8L
    A4,WS6 Ram Air Hood, Edelbrock Catback, SLP CAI, 85 Dry Shot
    1981 Firebird Trans Am
    http://members.cardomain.com/dreaded_hope
    camaro_ss_97_
    Guest
    i mounted mine under my speaker box in the back where the t-tops go. or you can mount it where your spare tire goes if you can do without that.
    Here's mine
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    Awesome! That's exactly how I want mine!!! I believe they are on top of the gas tank, right? You didn't have any problems putting it there? Also can you see good out of your back window?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    location
    try this, here's mine.http://cgi.ebay.com/ebaymotors/ws/eB...tem=4565148756 thanks jeremy
    n2ophx
    Guest
    Where I Mounted my bottle is where the t-top storage place was. I Took out the two plastic Holders of the tops and mounted my 15 lbs bottle horizontal. Tuck away
    Nashville, TN
    02SS6spd VERT!
    The only problem I have with that location is that I won't have anywhere to neatly tuck away the t-tops. I'd rather have them on top of the gas tank and sitting in the hatch. The only problem with that is that they won't be hidden and take away the sleeper effect.
    I've got some pretty dark tint on my hatch though. To make them a little harder to spot if someone is looking I could paint the tanks black and they'ed never knowwwwwwww.
    n2ophx
    Guest
    True True. The only reason I mounted my bottle in that location was because I rarely ever take of my t-tops and if I do, I usually just leave them at home. I get the sleeper affect with the bottle location and the location of my arming switch.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Just a little note to add to what everyone is doing here-I believe it is supposed to have the outlet tilted up so the gas will come out and not liquid.I'm no expert at this.One other idea that I've seen is to put it inbetween the two back seats,tilted up and facing forward.this gives easy access to the knob-is out of the way of the back seats(maybe a little cozy with them) and doesnt throw out the spare or t-tops.Just an idea.
    Senior Member predator's Avatar
    Little Rock, Arkansas
    1966 Corvette Coupe
    i thought it was tilted... so that the sypon wold pull liquid not gas... and saying this... it is also beneficial to mount the bottle with the bottom toward the back so momentum pushes the liquid where you want it... not away from where you are pulling it...
    When i get a car.... and i get ready for nos... i was actually thinking of linking 4 2.5 pound bottles so that they act as a 10 pound, but mount flatter... have to really look around... hoping i can devise a way to mount them in the spare tire hole... and still keep my spare...
    Nashville, TN
    02SS6spd VERT!
    That's a good idea too. Would you have enough nitrouse that way?
    1966 Corvette Coupe
    well it depends... if you link them all into one valve... then you wont know the difference between them and a 10 pound bottle... if you had them linked some how where one would open after another got low you would notice pressure spikes...
    my plan was to run a piping system that simply piped the outlets from the 4 tanks into a single outlet hose that ran to the front of the car... the only thing im not sure of is i wanted electric opening valves whether i can find a vlave that will control after the 4 come together or if i will have to get electric valves for all 4 bottles...
    you could always build a system of tanks under your passenger seat... and make it where your seat flipped up so you could turn it all on... (F & F reference for those who didnt catch that...
    as a side note... when you start looking at small nitrous bottles they make syphoned... and syphonless tanks... syphonesless tanks are designed to be mounted with the outlet pointing down... soooooo you dont have to worry about tilts or angles... gravity makes the nitrous go right where you want it to... this makes it possible to mount nos bottles pretty much straight up and down...
    a warning to you... i have no personal experience with nitrous... nor have i ever had a chance to REALLY examine useable space in an f body... i was just passing on some thoughts i have had in pre planning for my upcomming pruchase... verify things i tell you with an experienced user b4 seriously considering any of my sugestions...
    hope ive helped and keep me updated on what you learn.. it can only help me out later
    Quote Originally Posted by predator
    Manually open all the bottles and then use a solenoid on the line. Trying to hide little bottles on a 'F' body you could hollow top of back seat and use that.
    It's covered w/ a zipper accessible covering.Run the lines under carpet and go to a 'Money-maker hidden system. (Plumbed under the intake)
    quicky06
    Guest
    Quote Originally Posted by 227HAWK
    yea ive said that idea on here b4 the back of the back seat is thick enough
    Tire Smoker Jeff2002WS6's Avatar
    Anderson, IN
    2002 Pontiac Trans Am WS6
    I just found a nice plate from 860 Performance that mounts it in you spare tire well. Nitrous Dave has it on his website. Think I'm going to pick one up B-)
    02nhra
    Guest
    I like the spare tire well. A 15# bottle fits but probly not with a remote opener.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    sure does, and it will work look at my set up.http://cgi.ebay.com/ebaymotors/ws/eB...tem=4565148756. there are some video's to, thanks jeremy
    Member 02NHRAtransAm's Avatar
    VISALIA,CA
    BLACK / SUNSET MET.
    02 NHRA TRANSAM / 01 SS
    found this on a car on ebay
    looks good to me
    heres the rest of the car
    http://cgi.ebay.com/ebaymotors/TRMIN...QQcmdZViewItem
  1. Best bottle location and legal?
    By PUNISHERx216 in forum Nitrous
    Last Post: 03-10-2013, 09:58 AM
  2. Nitrous Bottle location
    By Corvettekid82 in forum Convertible
    Last Post: 12-18-2008, 07:00 PM
  3. bottle heater, FPSS, bottle opener, camaro door panels
    By oneBADDz in forum Parts For Sale / Trade
    Last Post: 11-04-2007, 09:37 AM
  4. Replies: 2
    Last Post: 06-03-2007, 06:46 PM
  5. Bottle location
    By 98Camarod in forum Nitrous
    Last Post: 09-04-2006, 03:36 PM
