Results 1 to 3 of 3
Thread: Opti spark problems I think
09-11-2005, 07:07 PM #1Junior Member
- Sep 2005
- Carbondale Pa
Metallic Black- 1994 Trans am GT
my upper Radiator hose blew out yesterday causing Antifreeze to run all over the motor and today after I put the new hose on the car it seems to have a miss at about the 3000 to 4500 Rpm range. I have a feeking that its the opti. I cleaned up and changed the ignition coil today and checked all the wires everything seemed to be fine. I do have a spare Opti but I never had ot change one before. Is there anyone here that has done one and can tell me how to make sure the timing is correct when I switch them.
09-11-2005, 07:51 PM #2Junior Member
- Denair, CA
Medium Quasar Blue- 1996 Camaro Z28
If I remember correctly the opti will only go on one way, I don't think that you can put it on wrong. It is also unlike a conventional distributor in that you can't turn it to change the timing manually.
09-11-2005, 11:57 PM #3i had the same problem today, the car cut off on me twice and was running like crap. i ended up spraying starting fluid in the vented opti lines (probably not the best thing to do) and after letting it sit for a couple of hours the car fired up and running fine now. I just replaced it a couple of months ago and don't feel like doing it again but it's not that hard it's just a bunch of bolts.
Originally Posted by lt1transamgt94
opti-spark
By 024mula in forum LT1Replies: 7Last Post: 03-10-2011, 06:54 AM -
opti spark
By camarostripes96 in forum LT1Replies: 7Last Post: 09-27-2007, 08:25 PM -
Opti Spark Oil Leak
By walbum in forum External EngineReplies: 0Last Post: 03-28-2006, 10:28 AM -
Opti Spark Problems
By dkishton1486 in forum LT1Replies: 56Last Post: 02-09-2006, 07:28 AM -
Opti Spark maybe?
By bandit95 in forum LT1Replies: 2Last Post: 09-19-2005, 03:40 PM
