Results 1 to 20 of 57
Thread: Opti Spark Problems
01-12-2006, 01:02 PM #1
Opti Spark Problems
What are the signs of an opti spark going bad? Its seems like mine is going
Thanks
01-12-2006, 08:08 PM #21BADLT1Guest
Why do you think it is going bad you tell us whats wrong and we can see if we can point you in the right direction.
01-12-2006, 09:29 PM #3SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
From experience I find that the main sign of an opti going bad is just owning one. . .
Nah, what's it doing? Give us some details as 1badlt1 said
01-13-2006, 05:45 AM #4
Well its ok when its cold but once it warms up it starts to hesitate really bad and misses bad. Its fine when im in nutural but when im in gear it does it.
01-13-2006, 05:49 AM #5Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
You my friend have a bad optispark. THat is the first sign of it going bad. Go ahead and get a new optispark and crank seal. They are bad to get oil in them and it breaks them down causing them to miss fire. We had about 5 of them go bad on the cars here at work.
Originally Posted by dkishton1486
01-13-2006, 05:56 AM #6
Question, Now ive had my car on a lift and seen the Opti how hard is it to change? What all has to come off if anything?
01-13-2006, 05:58 AM #7Story of My Life!!
- Commerce Ga
I know that the balancer has to off. Go to www.installuniversity.com I'm sure there is a write up on it there.
01-13-2006, 06:12 AM #8
I looked on the site and I cannot find a write up of it
01-13-2006, 06:16 AM #9Story of My Life!!
- Commerce Ga
I can't exactly remeber what all has to come off withoutlooking at one. I know the balancer and maybe the water pump. I can't remember. If your gonna do it yourself then learn as you go. Nothing too hard except the balancer.
01-13-2006, 09:26 AM #101BADLT1Guest
Hmm i nver did an opti spark but i know the water pump has to come AIR pump has to come off of course your intake duct and the balancer.
01-13-2006, 09:44 AM #11SUPREME member-oderator
- Nov 2005
- Lost in Texas
Yep, water pump, air, balancer. That's all the big stuff, just intake tubes, hoses etc beyond that. It isn't really that bad
01-13-2006, 09:47 AM #12
Could this be done in a driveway on a jack or no?
01-13-2006, 09:48 AM #13SUPREME member-oderator
- Nov 2005
- Lost in Texas
absolutely
01-13-2006, 09:53 AM #14
Ok sorry for being a bother but about how long hour range and 6 or a 12 pack of beer?
01-13-2006, 10:41 AM #15SUPREME member-oderator
- Nov 2005
- Lost in Texas
Depends how mechanincal you are. I can do it in an hour or hour and a half, might take upwards of 4-5 if it's pretty much an experiment for you. The more beer the more successful you will be and faster!!!
01-13-2006, 01:09 PM #16LT1KING
- Nov 2005
- Fontana, Ca.
Black/Black- 96 Vert Z28-RIP/94 TT Z28
Would'nt a bad Opti through an SES code?
01-14-2006, 01:43 PM #171BADLT1Guest
Originally Posted by GOODZ/BADZ
Yes and no, i dont know of any code for the opti but it will thrown a misfire code.
01-14-2006, 06:02 PM #18
What would be the easiest way to find out if there is a misfire code?
01-14-2006, 06:55 PM #19SUPREME member-oderator
- Nov 2005
- Lost in Texas
the ses light would be flashing
01-14-2006, 08:37 PM #20lee1rbcGuest
The opti is directly connected to the timing plate so you nd to remove wtr pump, crank pulley, air pump + brackets and radiator fans. You can get away with leaving the alt on. http://www.fierolt1.com/lt1_95_up_OptiReplace.htm Just make sure you buy a new GM opti and not a rebuild. The first time takes about 7 to 8hrs with hand tools and a floor jack. The third time I replaced mine I was done in 3 1/2.
opti-spark
By 024mula in forum LT1Replies: 7Last Post: 03-10-2011, 06:54 AM -
opti spark
By camarostripes96 in forum LT1Replies: 7Last Post: 09-27-2007, 08:25 PM -
Opti Spark Oil Leak
By walbum in forum External EngineReplies: 0Last Post: 03-28-2006, 10:28 AM -
Opti Spark maybe?
By bandit95 in forum LT1Replies: 2Last Post: 09-19-2005, 03:40 PM -
Opti spark problems I think
By lt1transamgt94 in forum LT1Replies: 2Last Post: 09-11-2005, 11:57 PM
