08-21-2006, 07:21 AM #1Evr sena bdgr killa snak?
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
Installing heads today, NEED advice!
I have a couple issues:
1. The gasket material off the old heads is on there pretty thick. I wanted to use a gasket remover (metal brush thingy for drills) to get rid of it. For one, I hope that brush isn't to rough, that it will damage the mating surface. Another problem is my engine valley is exposed, and I don't want that crap getting down there. Especially since my car has a HARD 97K, and there isn't ANY ridge on the cylinder walls, hell, it looks like it has just broken in good. Damn, I love the LS1. What is the best way to remove the head gasket material without making a mess?
2. What is the torque down procedure for LS6 heads? I need to know the torque specifications and order.
3. Why in the name of GOD did GM bolt grounds to the back of these heads? That is gonna be a real mothaf*cka to bolt that crap back on there. I would almost rather bolt it to a GOOD ground, such as the frame. It would ease head exchanges, plus I wouldn't think Aluminum would be the world's best ground material, anyway. I don't know, now that I think about it, that will be time-consuming the do it that way to.
4. While I got the heads off, do you guys think it would be wise to change the lifters too?
08-21-2006, 07:29 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
1. Whatever you use, be careful. The aluminum is very soft. You don't want to gouge it.
2. http://www.ls1howto.com/index.php?article=3
3. Don't forget the block needs to be grounded for spark.
4. Might as well get some Comp OEM lifters. Change out the lifter trays also.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
08-21-2006, 10:01 AM #3Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
Thanks Ed. Very helpful. I would have to wait to get those lifters, I think. That would delay my whole project at least 3 or 4 days. Hmmm...the stock stuff should be fine, right? I can inspect those lifters at least to make sure. What should I look for, like shakey roller tips? It wasn't ticking at all before the de-stall.
08-23-2006, 11:28 AM #4Member
- Aug 2006
- california
allllllllll black- 2002 35th z28
use laquer thinner and mild steel wool on the gasket left overs or softly hit it with a conditioner pad,
08-24-2006, 05:38 AM #5Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
Too late, I ended up using a wire drill brush and a sanding block for the stuff I couldn't get to. I used a plastic windshield de-icer scraper to get the big stuff off. Cleaning out the bolt-holes turned out to be a real time-consuming mofacka.
Next time I will try the thinner and wool trick. That is a good idea. Maybe you should email JMX at the HowtoLS1 website and see if he will include that in the install procedure. It sure would be helpful.
Check out what I got today for $200.. (also need advice)
By justinmc978 in forum Wheels and TiresReplies: 17Last Post: 10-11-2011, 04:00 PM -
Need advice installing transgo shiftkit.
By Street Fighter in forum DrivetrainReplies: 1Last Post: 05-05-2009, 04:59 PM -
need advice on installing Headers
By 99Trans_Am in forum External EngineReplies: 10Last Post: 03-29-2008, 01:18 PM -
Need Advice before 4:30 pm today
By Mike's TA in forum Firebird / WS6Replies: 7Last Post: 11-13-2007, 10:55 AM -
[B]installing magnaflow advice.....[/B]
By redz284u in forum External EngineReplies: 2Last Post: 06-23-2006, 10:49 AM
