Results 1 to 3 of 3
    Member redz284u's Avatar
    Littlerock, CA
    1998 SS
    [B]installing magnaflow advice.....[/B]
    im gonna put my new ls6 intake and a new magnaflow exhaust this weekend......i have the write up on the intake, but can find anything on the exhaust....
    is there a location i should cut to make it slide out better????im gonna do this in my garage, and plan on using a pneumatic grinder to cut the stock tube??????should i cut above the axle?????before the axle?????after the axle??????how much ground clearance will i need?????
    any help or tips will be appreciated.....
    98SS A4, TSP CLR LID, LS6 INTAKE, BMR SFC/STB/ LWR CNTRL & TRQ ARMS, KYB ADJ., HOTCHKINS SWAY BARS, MSD WIRES, JETHOT LT/ORY, MAGNAFLO CATBACK, EIBACH PROKIT, 19" TSW WHEELS, PERMA COOL TRANY COOLER.
    257.8 hp (MUSTANG-DYNO) b4 ANY MODS.
    13.6 1/4 mile
    Local Idiot Selah's Avatar
    Wilmington, De
    Cyclone Grey Metallic
    2005 GTO
    I think your "shift+/" key is stuck, may want to look into that....
    Cut the pipe right before the axle, it'll slide out real easy.
    All you should need for ground clearance is some ramps. just back it on.
    It's a fairly easy change, just takes a little time, but is well worth it. I went with the magnaflow too, sounds so awesome. Good luck!!
    St. Louis
    02 z28
    i too have the magnaflow, very easy to install, you shouldn't have a problem with that at all, i cut before the axle.
  1. Need advice, possibly legal advice
    By JHayesLS1 in forum Almost Anything Goes
    Last Post: 12-19-2009, 09:23 AM
  2. Need advice installing transgo shiftkit.
    By Street Fighter in forum Drivetrain
    Last Post: 05-05-2009, 04:59 PM
  3. need advice on installing Headers
    By 99Trans_Am in forum External Engine
    Last Post: 03-29-2008, 01:18 PM
  4. Installing heads today, NEED advice!
    By Roastem in forum Internal Engine
    Last Post: 08-24-2006, 05:38 AM
  5. Magnaflow Catback Advice
    By JettRink in forum External Engine
    Last Post: 05-14-2006, 04:34 PM
