    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    Exclamation skip shift eliminator!!!
    Yes i need some info, i have a 96 trans am LT1 5.7L , 6 speed and i just need some info on what the skip shift light in my car is for and what does the skip shift do? I have been looking at the skip shift eliminator and just wandering what it does??
    thanks
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    chances are you already have the eliminator because if you didnt you would know what it doesl. what it does is blocks 2 and 3 gear if you rev 1st over 2 grand. therefore forces you into 4th gear. this was done for insurance reasons among things. the light will always come on if you have the eliminator or not.
    Aug 2006
    academy,tx
    1996 Trans am
    ok if i do already have it where would it go so that i can check to see if it is on there? thanks
    Member Fedge's Avatar
    Feb 2006
    New Jersey
    1998 Trans Am M6
    under the car, look for a plug on the left side (driver) of the trans. There will be a plug in the trans to nothing and another wire near it with a plug on the end, should be wire-tied up to the harness or frame...
    the cleaner way to tell is if you can shift to second while the 'skip shift' light is on, then it's been done already. If the 'skip-shift' light stays on all of the time, then it was unplugged without an eliminator...
    95 Exploder
    01 R1 coming?
    Aug 2006
    academy,tx
    1996 Trans am
    ok i know i can shift to 2nd when the light comes on i have dont it before but i will go look
    Aug 2006
    academy,tx
    1996 Trans am
    ok i will go look
    Aug 2006
    california
    allllllllll black
    2002 35th z28
    SKIP SHIFT SUCKS ASS-4TH GEAR FROM 1ST AT UNDER 2000 RPM REALLY SUCKS just wait for a tune and delete it
    Member Ripper415's Avatar
    NY
    2002 Camaro SS
    i used to hate it when i first got my car, but after a while it didnt bother me anymore. when you really need to go through all the gears (like if youre racing someone) it turns itself off once you hit 3k rpms. otherwise for just cruising around town it really does help save some gas. friends of mine with other types of manual cars say they often go from 1st to 3rd or 1st to 4th to save on gas during city driving too.
    Member svt_eater's Avatar
    Ontario, Canada
    2002 Firehawk
    Quote Originally Posted by Fedge View Post
    Keep in mind that this could also have been done with a tuner program such as HP Tuners. My brother has it for his Grand Am and it will also work on our cars. I'm thinking of getting one of my own. It is much tidier to program it out than to have parts attached that stick out like a sore thumb.
    metro Detroit area
    I believe that if it were programed out via the ECM, the light would not function as well.
    Dec 2004
    SS: NBM, tan top
    Quote Originally Posted by svt_eater View Post
    it doesnt stick out at all
    Dec 2004
    SS: NBM, tan top
    you wouldnt ever know its there unless you looked for it
  1. Skip shift eliminator
    By dethinboots in forum GTO
    Last Post: 10-08-2011, 07:20 PM
  2. Skip Shift Eliminator
    By Whamhammer in forum Manual Transmission
    Last Post: 04-26-2011, 06:50 PM
  3. Question: Skip Shift Eliminator
    By kool-aide in forum General Help
    Last Post: 11-21-2009, 06:27 AM
  4. For Sale: Skip Shift Eliminator
    By Fran D in forum Parts For Sale / Trade
    Last Post: 03-08-2008, 05:30 AM
  5. Skip Shift eliminator
    By Nosws6 in forum General Help
    Last Post: 12-28-2007, 08:19 AM
