Results 1 to 20 of 20
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    Skip Shift Eliminator
    I was surfing for an inexpensive and nice skip shift eliminator harness. I came across someone selling a fuse they built to handle eliminating the skip shift. It is advertised for a corvette and shows it being located under the hood in the fuse panel.
    Is it possible to stick a fuse in the panel to eliminate the skip shift? Is this only for Corvettes?
    Tulsa,OK
    Quick Silver
    2002 Z06
    I've never heard of such a thing. I'm pretty sure the solenoid is controlled by the PCM or BCM so I doubt a single fuse will have anything to do with it.
    I personally don't get the need to remove it. I just learned to drive with it and never looked back.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    yes... and i've done it... it's a $0.05 fuse from radio shack... you have to unplug the line from your trans mission... insert the fuse and tape it up good then ziptie the line...
    http://www.installuniversity.com/ins...sity/index.htm
    that article says how to do it... i did mine back in 1999 and have not had a problem since...
    Quote Originally Posted by gnomee View Post
    you're missing out then...
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Yeah the Radio shack resister mod is the easiest and cheapest way to eliminate CAGS. It cost me $.50 for a 6 pack of resisters in `98 and I did 6 cars wth it.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Deltona, FL
    2002 Camaro Z28
    i'm not trying to be a jerk, but Install U uses a resitor not a fuse. What I am talking about is a fuse under the hood.
    Deltona, FL
    2002 Camaro Z28
    I know what you mean. I even looked in the car manual for info on what triggers it. I have basically found the rev point to go 1st to 3rd instead.
    I wanted to eliminate the skip shift to teach my wife how to drive the car. It is difficult teaching someone when the dumb thing kicks in on you.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    I honestly have never heard of it. I don't see how installing a fuse under hood would do it as the wiring from the skip shift goes straight to the PCM and not anywhere near the underhood fuse box.
    Quote Originally Posted by kool-aide View Post
    there is no fuse for it...
    only way to do it is to spend $30.00 for the part out of a catalog or spend the $1.00 at radio shack...
    Senior Member
    Jacksonville, FL
    You need a resistor, or skip shift eliminator to plug in (resistor) to bypass it. On your car the ENG SEN fuse controls the MAF, H02S, reverse lockout and skip shift. Only other option I know of is have it turned out.
    Wow 3 post answers at 03:59.
    Deltona, FL
    2002 Camaro Z28
    ok, so it sounds like the idea of an under the hood fuse is unique to the corvettes. The ad did say a C6 Vette. I thought I would ask just in case someone had stumbled on to something. Maybe this is one more reason to dream of owning my first Vette, lol....
    Apr 2002
    San Jose
    Nov 2008
    harrisburg pa.
    02 vette vert
    what happens if you just unplug the harness from the solenoid?
    Deltona, FL
    2002 Camaro Z28
    you know what....that is a darn good question.
    Any one? What happens if you unplug it? Will the PCM freak out on you?
    Tulsa,OK
    Quick Silver
    2002 Z06
    I am pretty sure the check engine light will come on. That would be the only reason sticking a resistor in there would be a "fix"
    Deltona, FL
    2002 Camaro Z28
    well i would try it on mine, but it is a little late to be crawling on the ground. maybe I can try it tomorrow, .
    `98 Formula M6 HdTp
    If you just unplug it, it will throw a code to the ECM and trigger the SES light.
    The resistor loops the signal and tricks the ECM into thinking the system is active. So basically the Skip Shift light will still come on under the correct conditions but you can put it into what ever gear you choose.
    Deltona, FL
    2002 Camaro Z28
    tx. I figured that is what the resistor was doing. just wanted to know if unplugging it would do anything crazy. if all it does is harmlessly turn on the SES light. Well thats not so bad. of course if you are under there unplugging it, why not jam the resistor in there. I have my fingers crossed for that too good to be real ebay item, lol....
    i picked up a used, advert as working, condition a/c panel for a steal. i figure with a little patience a nice skip shift plug in will pop up too.
    I would go the resistor route, but i'm not a big fan of taping with the intent of blocking water. That just sounds like my bad luck going south on me fast.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It can be turned of through tuning as well.
    Deltona, FL
    2002 Camaro Z28
    very nice, i did not know that. It's like a little list of annoying things you wanted tuned out:
    Skip Shift
    AIR
    O2s, down stream
    etc...
    thank you i will keep this in mind.
  1. Skip shift eliminator
    By dethinboots in forum GTO
    Last Post: 10-08-2011, 07:20 PM
  2. Skip Shift Eliminator
    By Whamhammer in forum Manual Transmission
    Last Post: 04-26-2011, 06:50 PM
  3. For Sale: Skip Shift Eliminator
    By Fran D in forum Parts For Sale / Trade
    Last Post: 03-08-2008, 05:30 AM
  4. Skip Shift eliminator
    By Nosws6 in forum General Help
    Last Post: 12-28-2007, 08:19 AM
  5. skip shift eliminator!!!
    By camarostripes96 in forum Manual Transmission
    Last Post: 08-22-2006, 02:10 PM
